Forum archive - Progress percentage is under-reported
http://www.supermediastore.com/
Forum Archive Home -> ffmpegX bugs and suggestions -> Progress percentage is under-reported
tomf84 posted 2009 Jan 03 13:06
For some reason when encoding region-free DVDs from a VIDEO_TS folder on my hard disk into xvid (avi mencoder, customised preset), the progress percentages shown in the ffmpegX Progress window are much lower than reality
i.e. I set off a conversion and the progress does go up, but very slowly, to about 20% or so at most, then jumps to 100% completion and the video is indeed properly complete.
Is this a bug or a known issue?
Tom
Case posted 2009 Jan 03 19:19
There are some known inaccuracies in the progress percentage, but I do not recall the behavior that you describe.
tomf84 posted 2009 Jan 04 10:29
Given that this is reproducable, should I file a bug report, and if so, how?
Case posted 2009 Jan 04 10:40
There is a "ffmpegX bugs and suggestions" forum here, where it could be posted. Perhaps you could use the "Report this post" link (in the first message) to ask a moderator to move this topic there.
tomf84 posted 2009 Jan 05 04:34
Done. Thanks for the pointer.
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
