Forum Archive Home -> Authoring (VCD/SVCD) -> Procoder SVCD
Procoder SVCD |
| kippard posted 2008 Dec 16 19:58 |
| I'm rendering an Xvid to SVCD in ProCoder 3 - looks like ProCoder ismaking an m2p file. Sorry for the (doubtless) redundant question (I checked guides, but I'm not sure): How do I get a working CD-R SVCD? I have IMGBurn. Thanks! |
| guns1inger posted 2008 Dec 16 20:07 |
| You have to author it using an svcd authoring package. Having never made an svcd, I can't recommend one for you. |
| aedipuss posted 2008 Dec 16 20:30 |
| normally the files would be .mpv and .mpa or a combined .mpg. check the .m2p and see if it's a vid+aud 480x480 mpeg-2. if it doesn't have an audio channel you'll need to make one with under 384kbps MPEG-1 Audio Layer II out of your source audio and then mux them into a mpg.
you can use vcdeasy to generate the bin/cue files or burn it to cd once you have a compliant mpeg-2 |
| kippard posted 2008 Dec 16 20:43 |
| I think ProCoder will mux them when it's finished, 480x480 mpeg-2. It's pretty bad, I know, but how do you burn a bin/cue to CD-R with IMGBurn - any idea? Thanks, guys. |
| aedipuss posted 2008 Dec 16 21:19 |
| select the cue file with imgburn in write mode. it is one of the few burning apps that will correctly burn svcd's m2f2 format. |
| kippard posted 2008 Dec 16 21:22 |
| You rock. |
| classfour posted 2008 Dec 17 02:28 |
| Why SVCD? DVD-R media is Cheap. DVD-R/RW drives are under $20 online. FREE DVD players are abundant on www.videohelp.com (please look up Media Player Classic). LightningUK does have the best burner bar none, but I'm trying to work with you on this one. |
| tomlee59 posted 2008 Dec 17 10:51 |
| I can't speak for the OP specifically, but I can offer some possible answers generally: There are some people who want their media playable on older computers that do not have DVD drives, but which are otherwise capable enough to decode MPEG2 at the required speed. "Get a newer laptop" is not always a practical answer. Or maybe because the cheap DVD-R media they could use is too crappy, and they have a gigantic quantity of good CD-R media they want to use up. Or maybe because the end users are going to be kids who may mistreat the discs, and CDs are more robust than DVDs. Etc. |
Login/Register to our forum to be able to post here.
