Forum archive - Problems with WTV
http://www.supermediastore.com/
Forum Archive Home -> Video Conversion -> Problems with WTV
Problems with WTV
version187 posted 2009 Nov 03 10:44
Searching these forums and google for the past 3 hours to no avail hopefully someone can help me out with this :(
I have a tv show I recorded through WMC that i'm attempting to convert to divx for storage, however I have nothing that will do this directly and I have to first convert the wtv file to a dvr-ms file. this isn't a problem in windows 7 (build 7600) however when I run the dvr-ms file the audio is all messed up (it's just static) and I can't figure out why.
Does anyone know what might be causing this? or any ideas on what else I could use to convert the wtv file to another format?
Any help would be greatly appreciated.
Baldrick posted 2009 Nov 03 11:09
How do you convert to dvr-ms? what software?
Have you tried dvrmstoolbox?
And visit also http://thegreenbutton.com/forums/ , a good windows media center forum.
version187 posted 2009 Nov 03 12:04
Right click > Convert to dvr-ms Format, checking out the forum now.
Also to add the files are 720p and 5.1 digital audio.
version187 posted 2009 Nov 03 18:38
dvrmstoolbox doesn't help, converting from dvr-ms isn't the problem, the sound is fine as wtv it becomes static when converted to dvr-ms.
Is there a tool to demux wtv files?
Login/Register to our forum to be able to post here.
Replay Media Catcher lets you record ANY streaming video and save on your computer! More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
