Forum archive - Problem with tsMuxeR...
http://www.supermediastore.com/
Forum Archive Home -> Authoring (Blu-ray) -> Problem with tsMuxeR...
hiimbored posted 2009 Oct 04 23:02
I used tsMuxeR to author an AVCHD disc the other day and it came it fine. I combined 5 episodes of a show, and used the custom chapters option to "separate" each episode. But then today I tried to do the same to the next 5 episodes and I got this error:
tsMuxeR finished with error code -2.
tsMuxeR output:
SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net
Decoding H264 stream (track 1): Profile: High@3.1 Resolution: 1280:720p Frame rate: 23.976
H.264 stream does not contain fps field. Muxing fps=23.976
H264 bitstream changed: insert nal unit delimiters
H264 bitstream changed: insert pict timing and buffering period SEI units
Decoding AC3 stream (track 2): Bitrate: 384Kbps Sample Rate: 48KHz Channels: 2
B-pyramid level 1 detected. Shift DTS to 2 frames
H264 bitstream changed: insert SPS/PPS units
Errors:
SPS picture order 6 not supported.
Anybody have any idea what the problem might be?
johns0 posted 2009 Oct 05 00:03
Use multiavchd to author your avchd instead.
hiimbored posted 2009 Oct 05 14:47
I just tried using multiavchd and it completely confused me. I'd rather use tsmuxer if anybody has any idea why it's giving me problems all of the sudden.
tkolt posted 2009 Oct 05 15:11
the only hard thing/confusing aspects of multiAVCHD is the menu options..period. its not hard.
i'd use that as the last posted noted.
hiimbored posted 2009 Oct 05 17:02
I tried multiavchd again and it just froze up and then an Windows message popped up saying that the program had stopped working. Then the same thing happened with tsmuxer. Any idea what the problem is? I've tried a bunch of different files but I just can't get it to work anymore.
johns0 posted 2009 Oct 05 21:16
Usually when those programs freeze and crash is when you either have a corrupt file and or no codecs installed for those files,what codecs do you have installed and do the files play all the way through on your computer with no problems?
hiimbored posted 2009 Oct 05 22:44
johns0 :
I don't know what codecs I have installed; which ones should I have?
johns0 posted 2009 Oct 05 22:53
Install ffdshow and haali media splitter,uninstall k-lite and any other codec pak if they are on your system and dont listen to anyone who says k-lite is good to install cause it causes problems like you are having.
multiAVCHD posted 2009 Oct 06 03:43
Such error is not related to anything in the user's configuration. SPS order error means that the video stream in the input file has broken/incompatible blocks and cannot be processed into m2ts container.
A thing to try is to DEMUX these files to video+audio and then remux back into MKV and try again.
Dean
p.s. Another thing to try (although I doubt it will help) - remove the checkbox for [-] Continually insert SPS/PPS
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
