Forum archive - Problem backing up my copy of transformers 2,i got it ripped but can't burn
http://www.supermediastore.com/
Forum Archive Home -> DVD Ripping -> Problem backing up my copy of transformers 2,i got it ripped but can't burn
sscottsa posted 2009 Oct 22 16:05
every time i tried to burn it with dvd shrink this just keeps popping up on me and i cant get it to burn, dvdfab 6 failed to rip it the only way i got it ripped was using ripit4me using movie only and then i used dvd shrink to burn it with a verbatim dvd-r 16x speed but i only burn at 2x
do anyone have any ideas what i am doing wrong here?
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 11:35:32 AM
Nero API version: 6.6.0.16
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 0, 16b
Recorder: <HL-DT-ST DVDRAM GMA-4082N>Version: HN03 - HA 1 TA 0 - 6.6.0.16
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : TOSHIBA MK1032GSX atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVDRAM GMA-4082N atapi Port 1 ID 0 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GMA-4082N D: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1013MB (1038316kB)
Free physical memory: 536MB (549232kB)
Memory in use : 47 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
22.10.2009
NeroAPI
12:26:07 PM #1 Phase 112 File APIProgress.cpp, Line 276
DVD-Video files reallocation started
12:26:07 PM #2 DVDREALLOC -5 File DVDVideoCompilation.cpp, Line 1189
Violation against DVD specification detected
12:26:07 PM #3 Phase 115 File APIProgress.cpp, Line 276
DVD-Video files reallocation failed
12:26:07 PM #4 Text 0 File NeroAPIBurnFS.cpp, Line 212
Failed to realloc DVD video files
mrswla posted 2009 Oct 22 18:18
see this.
Login/Register to our forum to be able to post here.
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
