Forum archive - Printable Dual Layer DVD's
http://www.supermediastore.com/
Forum Archive Home -> Media -> Printable Dual Layer DVD's
ozab posted 2009 Oct 07 10:33
Hello - I need some printable Dual Layer DVD's today.
Does anyone know if Bestbuy, Officemax or OfficeDepot sells them?
I am in Chicagoland area.
stiltman posted 2009 Oct 07 11:17
The only DL media I use is Verbatim. I have never seen their printable Data Life Plus in B&M stores
jman98 posted 2009 Oct 07 12:39
Verbatim makes a DVD+R DL inkjet printable disc under their DataLifePlus brand. You'll almost certainly have to order them online to get them.
Pro - Made in Singapore.
Con - Only rated at 2.4x speed. Very expensive (20 pack sells for $36.99 at one online retailer known for low prices).
If you must have them today, buy what you can but you'll be throwing your money away. Non-Verbatim discs will be junk and some will no doubt fail to burn correctly or playback correctly.
stiltman posted 2009 Oct 07 13:12
They also make 8x media too
http://www.verbatim.com/products/detail.cfm?product_id=0FD67579-1 ... 71D951F627
You also might try OfficeMax.
http://www.officemax.com/catalog/sku.jsp?skuId=21914608&cm_mm ... 25-1306518
They list them, but I don't know if that is online only.
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
