Forum Archive Home -> Programming -> Possible To Make A VDub Script To Cut Segment From Video?
Possible To Make A VDub Script To Cut Segment From Video? |
| onesikgypo posted 2009 Jul 06 04:59 |
| Hi,
I was just wondering if it was possible (and if so, if someone could provide) - a script i could run from the command line, such as VirtualDub.exe /s script filename.avi, which would cut a set segment (i.e from 5m - 10m) then save it (If it's not possible to do that, then perhaps VirtualDub.Exe /s script - then selecting the file - though the first would be preferred) The only change to the default vdub settings is to change the video from full processing mode, to direct stream copy - ive saved the "processing settings" in vdub - however im unsure where to go from there. If anyone could provide any assistance, it'd be greatly appreciated. P.S If there is another program that can do it as efficiently as VDub - and would be easier to do this type of thing, suggestions as to other ways of just cutting a segment then saving it are also welcome. Thankyou. ------------------------------------=========================================---------------------- No Longer An Issue - Easily Done With Mencoder. Thanks. |
Login/Register to our forum to be able to post here.
