Forum archive - Philips DVP 5990/37 HDMI problem
http://www.supermediastore.com/
Forum Archive Home -> DVD & Blu-ray Players -> Philips DVP 5990/37 HDMI problem
daydaydream posted 2009 Jan 21 23:34
my 5990 HDMI was working @1080p with my LCD properly for a few weeks. Just now the HDMI connection starting showing a orangish color instead of the original blue/grey color. I tried the following:
1. the YPbPr connection is normal at 480p
2. the HDMI cable is normal, I use my computer to connect and it shows all the color normally on the LCD
3. I tried flashing the firmware again, no luck.
could it be the problem with the HDMI port on the player itself? any other thing I can try?
Thanks for the help in advance.
redwudz posted 2009 Jan 22 00:16
Unfortunately, that may be the problem. :( There was another post here with the same problem a while back. May be a defect that surfaces with the player on occasion. If the warranty is still in affect, probably trade it in.
But HDMI negotiation is problematic at times. If your cable and your display works properly, then the 5990 HDMI port may have died.
Or others may have some ideas.
And welcome to our forums. :)
victoriabears posted 2009 Jan 22 00:38
Mine did that, unplug it leave for 2-3 minutes-plug it in again
daydaydream posted 2009 Jan 22 19:20
victoriabears :
with the player on or off?
victoriabears posted 2009 Jan 22 21:03
off I suppose, do not think it matters.
You are resetting it, fixes a lot of common av problems.
daydaydream posted 2009 Jan 22 22:35
victoriabears :
Thanks! it works after unplugging the power cable.
victoriabears posted 2009 Jan 23 00:26
Really ! so we do not need hydro anymore
:shock:
sorry couldnl;t resist it
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
