Forum archive - Philips 642 and the Optical Output
http://www.supermediastore.com/
Forum Archive Home -> DVD & Blu-ray Players -> Philips 642 and the Optical Output
Scooter_NJ posted 2005 Jan 11 16:36
Anyone else running into problems with the optical output on this piece, ESPECIALLY when watching DIVX/XVID??? Mine is DAMN noisy/static-ish when using the optical into my Denon.
rayray posted 2005 Jan 12 00:23
use the coaxial output then, I don't have any problem with the coaxial output. I reckon coaxial always sound better than optical anyway.
wildo2ne posted 2005 Jan 12 01:11
Probably your receiver is sucky, I am using optical out on a harmon kardon and it sounds awsome
8) wildo2ne
doppletwo posted 2005 Jan 12 01:13
What is your audio Output setting? On the DVD player.
rayray posted 2005 Jan 12 18:07
Depends on what type of sound you listen to. Listening to classical music DVD, I find optical a bit harsh, but the dynamics of optical is better, so the explosion sound is more dynamic with optical output. Personally, I couldn't care less how loud the explosion sound on my system.
So you reckon Harmon Kardon is the best? I'm using Krell, have you even heard of that brand yet?
The 642 is of course just a second DVD player, as it nowhere fits into high end system. But then, I don't think there is yet a high end DVD that plays DIVX.
Login/Register to our forum to be able to post here.
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
