Has anyone ever seen this code appear on the display, DB7FC27E19? I see it when turning the unit on, at first it shows WAIT, then it just turns off (the stand-by light never turns green). Any fix for this?
The last time a saw a list of error codes, they were 3-4 digit codes...like E05. That looks like gibberish. You may want to verify through Philips or a repair shop, but it is likely cheaper to replace than to repair.
Google is your Friend -
DB means digital board, so it can probably be fixed by replacing the digital board.
However, it will be much cheaper to buy a new unit than to have Philips repair it. -
It's been a while, this recorder has been sitting gathering dust. I had some free time and figured you were right about the digital board, but considering this recorder was fairly new I tought it migth be a case of bad solder. The way they solder electronic boards you often end up with cold solder joints; mostly on components with larger pins. I simply removed the power supply and the digital board and re-soldered the pins from the connectors. That's all it took to fix the problem.
This is just a reference for others trying to upgrade the firmware of their DVDR985. I spent some time searching for an answer and the only one I found lead to a dead site.
The last version is 6.3 a.k.a ff12x. All the files I downloaded from Philips' website wouldn't work; during the upgrade the display would show "FILE EMPTY" and eject the disc. I tried the files for DVDR985/171 (my model #), DVDR985/172 and DVDR985 ver. 1.01 with same the result. I did a file compare between all 3 and they were identical.
The solution is to search the Philips site for DVDR985A99 (looks like the file is on the US site). You will find a 68.61 MB zip that contains the same files as the ones I tried before (except dvdr1000.001 is bigger) and a bunch of others.
P.S. I tried swapping the two dvdr1000.001's with the first fileset I got and it doesn't work. So, when it says FILE EMPTY, it must mean file missing.Last edited by nic2k4; 11th Jun 2010 at 01:34.
I still have my firmware disc from my DVDR985.
EDIT - it is 139MB dated from 2004(?).
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Philipps DVP3360 DVD player displays STOP / ROOT
By offytuf in forum Newbie / General discussionsReplies: 0Last Post: 22nd Mar 2011, 16:06 -
source filter error (Error=80040241) when playing HR Avi
By mwm in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 10:03 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
