Forum archive - No cddrive found. Understanding CDRDAO info
Forum Archive Home -> VCDEasy General -> No cddrive found. Understanding CDRDAO info
gargoyle_xlvii posted 2005 Apr 29 22:02
I have a HP8200 writer. It is not found by VCDEASY so I went to the CDRDAO site for infomation on it. However I do not understand what it is trying to tell me. Could some one explain it.
HP CD-Writer+ 75XX, HP CD-Writer+ 8XXX, HP CD-Writer+ 9XXX, SONY CRX100
The firmware restricts the possible disk types in multi session mode (DAO only) to one of the following:
* Pure audio CD.
* CD-EXTRA where the 1st session contains only audio tracks and the 2nd session contains 1 data track.
Further restrictions:
* The length of the 1st track's pre-gap is restricted to a certain amount.
* Cue sheets with ISRC codes are rejected of the COPY flag is set. This might be fixed in future versions.
Does this mean I can not use it to burn VCD's?? Even if I use the BIN/CUE.
redwudz posted 2005 Apr 29 22:49
Not that I know much about that burner, but I see nothing from the CDRDAO site to prevent you burning VCDs.
I don't use VCDeasy that often so I'm not sure why it can't find the drive.
Looking at the CDRDAO site, that drive is listed as working.
gargoyle_xlvii posted 2005 Apr 30 07:53
Well to tell you the truth, I just do not get it. Yesterday when I posted this request for help the HP8200 would not show up under the CD Writer list. However today it does.
I do have to says that I did install the orginal software for the Hp8200 so this might have added something that was missing.
So I quess that I do not need any help, but thank you any for you help.
Login/Register to our forum to be able to post here.
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
