Forum Archive Home -> Media Center PC / MediaCenters -> No audio from MKV on WDTV media player
No audio from MKV on WDTV media player | ||
| kyrcy posted 2009 Oct 20 13:07 | ||
| I can't hear audio when playing the following MKV on WDTV media player:
Video: MPEG4 Video (H264) 1280x720 23.98fps [English (Video 1)] Audio: DTS 48000Hz 6ch [English (Audio 1)] Subtitle: UTF-8 [English (Subtitle 1)] The WDTV is using composite (RCA) outputs. Is this normal? | ||
| jagabo posted 2009 Oct 20 13:12 | ||
| The WDTV doesn't have the ability to down mix DTS to stereo (RCA outputs). If you plug the digital audio port into a receiver with DTS decoding you'll get audio. The new WDTV Live (aka WDTV2) has DTS down mixing to stereo. | ||
| mh2360 posted 2009 Oct 20 13:28 | ||
| You could use PopCorn MKV AudioConverter, which simply converts the audio in an MKV file from DTS to AC3.
It's simple enough to use, but you have to download a few small programs which it needs before you can use it. | ||
| kyrcy posted 2009 Oct 24 12:24 | ||
| How long does it take to convert the audio from DTS to AC3? | ||
| mh2360 posted 2009 Oct 24 13:27 | ||
With a 90 min MKV, around 5 minutes or so on my system. |
Login/Register to our forum to be able to post here.
