VideoHelp.com forum archive
http://www.supermediastore.com/
Forum Archive Home -> Computer -> Newegg Promo codes
Newegg Promo codes
budz posted 2008 Sep 30 23:36
:o Newegg has the CM 590 case on sale for $39.99 after using a promo code. If I was to purchase 2 of those cases would I be able to get $20.00 off each case? Any comments will be appreciated! Thanks! :)
stiltman posted 2008 Oct 01 12:16
I've never liked cases with the PSU on the bottom
Number Six posted 2008 Oct 01 16:27
The best way to find out is to put 2 in the shopping cart and add the promo code - then see what discount it gives you.
Stiltman has a good point - If the power supply is on the bottom, then all the heat from it will fill the case - hot air rises .
Skith posted 2008 Oct 01 16:31
[s:06ce06ccbf]no, you can only get $20 off one case if you buy two.[/s:06ce06ccbf] mabey
Usually you can only use one promo code per item/purchase/receipt (newsletter promo codes)
[edit: I suppose it depends where the promo code came from, and the specific terms tied to it. ]
budz posted 2008 Oct 05 21:48
:) Thanks for the replies. I did contact Newegg and it's only one per account. I got the CM 590 case on Friday afternoon. It now houses my Intel Conroe E6400 2.13ghz cpu that's overclocked to 3.20ghz using a Enzotech Extreme X heatsink & Scythe S-Flex F fan. I actually prefer the psu on the bottom since heat rises and the CM 590 has two top exhaust fans. This case has good airflow with my cpu temps at 34c loaded, video encoding w/dvdrb pro 38c and system temps 40c. I also have the CM 690 which houses my Intel Wolfdale E8400 cpu that's overclocked to 3.60ghz. These CM cases have lots of room, good airflow and cables can be hidden behind mobo for good cable management. :wink: :)
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
