Forum archive - Nero Won't see my DVD Burner !!! HEP ME HEP ME!!!
http://www.supermediastore.com/
Forum Archive Home -> DVD & Blu-ray Writers -> Nero Won't see my DVD Burner !!! HEP ME HEP ME!!!
THE_oldguy posted 2008 Jun 13 22:31
Just got an AMD Duel core pro box /loaded all the old hardware from older box ,*(including Optiarc DVD thats been good as gold), and now Nero won't see my DVD drive. All it lists is an "Image recorder". Seems I'v been thru this before but can't remeber the fix. Some one PLUEEEZZEE help !!!!!!!!
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4400+, MMX, 3DNow (2 CPUs), ~2.3GHz
Memory: 2046MB RAM
[/u]
redwudz posted 2008 Jun 13 23:20
Does the burner show up in 'My Computer' and otherwise work properly? What version of Nero and what OS are you using? Assuming XP. Does ImgBurn detect the burner?
If so, I would uninstall Nero, then re-install and see if that fixes it. You might also run Nero Clean before re-installing. http://www.nero.com/enu/downloads.html Go to the version you are using, then 'Tools & Utilities' for the proper clean program. It may have been something you installed after Nero, but a re-install usually works if the problem is with Nero.
EDIT: And I just noticed this is in the wrong forum. Moving you to DVD & Blu-ray Writers. :)
THE_oldguy posted 2008 Jun 14 00:04
Have nero 5 and have unistalled several times . Will goto d/l site and try this.
Let you know :>(
redwudz posted 2008 Jun 14 00:25
Nero 5 is very old and may have problems with newer burners, especially if you updated your OS. I'm surprised it worked before with your burner. I had to upgrade some time ago when I got a newer burner, as Nero 5 wouldn't recognize it. And I liked Nero 5. :(
The newer Nero is a bloated, expensive piece of software if you just want to burn a disc, IMO. I went to ImgBurn and took Nero off my systems. I use other tools in it's place. But try the Nero clean tool. Nero doesn't uninstall cleanly and needs that program if you want to re-install.
bevills1 posted 2008 Jun 14 10:45
Is that Optiarc drive a NEC model earlier than 7200, and is it a problem with -R media? If so, it may have acquired the common -R read proflem detailed at http://club.cdfreaks.com/f86/nec-optiarc-dvd-r-reading-problems-209168/.
Go to
http://www.google.com/search?hl=en&q=nero+6+oem+suite+-+free+ ... gle+Search to find Nero 6 from various sources for under $10. I've used Nero 6 for 5 to 6 years with zero problems and have avoided newer versions due to problems I've seen posted plus the bloat factor for newer Nero versions.
handyguy posted 2008 Jun 14 11:06
Try:
ImgBurn
Website: http://www.imgburn.com/
License: Freeware
Download File size:1.5 MB
Operating Systems Supported: 95, 98, Me, NT, 2000, XP, 2003 Server, Vista
64 Bit Capable: No
Portable Version Available: No
Additional Software Required: None
jman98 posted 2008 Jun 14 11:37
This happens all the time with Nero. The quickest solution is to uninstall and reinstall.
bevills1 posted 2008 Jun 14 11:46
This has never happened to me with Nero 6 with the 1 exception being only with a NEC 3520 drive that has the -R read problem affliction referred to in my first 6/14 post here. Even reinstalling Nero doesn't fix that problem, or even reinstalling Windows doesn't fix that problem either which is no fault of Nero. I've read good things about IMGBurn too, but I don't know if it fixes the NEC -R read problem because I've not used IMGBurn.
Edit: The -R read problem occurs only for burned discs, and that's likely not the problem if the drive isn't seen at all by Nero which I just realized was the problem. Therefore I'd suggest to first make sure an 80 wire IDE cable is used, and try switching IDE cables to determine if it's a bad cable. You might also try uninstalling the drive from Device Manager and reboot to have Windows reinstall the drive, i.e. if it's seen in Device Manager.
THE_oldguy posted 2008 Jun 14 19:52
Did what you sugested. Aparently " Cleaning" system did the job.. Do have Nero 6 and AM using Img Tool Burn with ease now. Thanks again for the help.
:D
redwudz posted 2008 Jun 14 20:22
Good deal. :D ImgBurn is a great option if you just need to burn a disc. Nero doesn't uninstall very well and the 'clean' tool is really a requirement if you are re-installing or updating the program. Nero 6 is decent, I have used it. I still miss the simplicity of Nero 5, though. :(
brandz1 posted 2009 Jun 23 08:22
Well Boys here your problem, and i want to share this with the rest of the world!
The brandz got into it and i worked it out as usual!
:?: Nero wont see any devices in Drop down combo box? Hmm Any version 5 to 8
go here and read this web page, trust me its your problem you have virus! :D Its called gxvxcserv.sys trojan is a fresh version of W32.Tidserv trojan also known as Trojan-Downloader.Win32.Agent.brpo
Go here and follow the instructions on removal!
SPAM
All so if this helps ya report back here i would like to know if i helped anyone. Later Dudes!
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
jman98 posted 2009 Jun 23 08:26
B.S., brandz1. B.S.
This is a well known problem with Nero and the fix is to reinstall or use something else like ImgBurn.
We don't like it when people dig up old threads and post to them, especially when it's commercial spam.
Click on his link at your own risk. I would not advise it. I've reported the post to the moderators.
Login/Register to our forum to be able to post here.
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
