VideoHelp.com forum archive
http://www.supermediastore.com/
Forum Archive Home -> Digital TV / DVB / HDTV -> Neon Hot Pink Problem with HDTV
SLB131 posted 2008 Aug 31 07:46
My HDTV, of 2 years, has started to show neon hot pink colors when the color should be black. This occurs after 10-15 minutes after turning on the TV, and stays for about 20-30 minutes, than goes away. I've done some quick troubleshooting: called the cable company (yes, I'm receiving the HD input); the hot pink replaces the black color even when watching DVDs. Has anyone experienced this problem? Or should I buy a new HDTV? Or send it in for repairs? The model is a no-name brand Norcent, 36". (I'm hesitant to buy a new HDTV if the repair is less than $300.)
Epicurus8a posted 2008 Aug 31 15:00
I haven't experienced that problem before. But if the problem occurs on all the inputs, I strongly suspect the TV is shot. No-name TVs are difficult to fix because the makers frequently don't provide support to repair shops. I'd send it to the recycler and buy a name brand TV next time. Costo generally has a good selection and they automatically extend the warranty to two years.
Good Luck!
edDV posted 2008 Aug 31 15:28
SLB131 :
Is this a direct view CRT? Rear projection CRT? DLP? ???
If you google by model number you may find others with similar problems.
SLB131 posted 2008 Sep 04 05:30
It is a direct view LCD.
edDV posted 2008 Sep 04 12:49
SLB131 :
That is an unusual failure mode for an LCD TV. If it isn't a cable/connector issue, it's probably a PC board failure.
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
