    Dec 2007
    India
    Hi..
    I got a Samsung DVD Recorder (DVD R-160) from US (which has Region Code-1)..
    I want to play the DVDs in India..
    Could you please help me out to unlock it for multi-region..
    Thanks in advance..
    Reg,
    Suj
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Even if 160 isn't listed, 155 is. Tried any/all of these suggestions: https://www.videohelp.com/dvdhacks/samsung-dvd-r155-us-version/8192 ?
    Then comes the TV system issue: US is NTSC, India PAL. NTSC equipment usually won't play PAL (something a hack can't cure).
    /Mats
  3. Banned
    Freedonia
    Although many DVD players sold in the USA are able to play PAL DVDs and convert between PAL and NTSC, all can't do this. Mats is right that even if you are able to unlock this player, you may have playback issues if this player can't output a PAL signal or your TV can't accept NTSC video input.
    Also note that all DVD players can't be unlocked. If your player can't be unlocked, then there is nothing you can do about it. Try the suggestions for the DVD R-155 model and maybe you will get lucky.
