Forum archive - Need help unlocking Sony DAV-DZ150k dvd player - pls & thanks 4 help!
http://www.supermediastore.com/
Forum Archive Home -> DVD Recorders -> Need help unlocking Sony DAV-DZ150k dvd player - pls & thanks 4 help!
Aussie Gal posted 2008 Jun 06 23:18
It is region 4 currently as I am in Australia -- but have heaps of dvds from USA that we need to play.
Thanks soooooo much for your help -- Jacqui :)
aedipuss posted 2008 Jun 06 23:33
not usually an option with sonys. sorry but they are not readily hackable. no known way with that model either.
Aussie Gal posted 2008 Jun 07 00:05
Thanks -- you have confirmed my research and I am going to return it to the store. There is just no point keeping it if I can't play the dvds that I want. Any suggestions on a home theatre dvd that is easy to unlock -- but not top of the range? Doesn't need to be blu-ray either.
Aussie Gal posted 2008 Jun 07 02:17
Actually the guy in the store told us that they are already unlocked......although they say "region 4" on the box -- and here am I trying to find the unlock code.....we took it home....tried region 1, region 2 dvds and they worked!
The dvd was already unlocked. No need to hack into it. Despite all of the feedback to not buy a Sony -- this one works perfectly fine.
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
