VideoHelp.com forum archive
Tmpg-inc
Forum Archive Home -> Software Playing -> my VirtualDubMod doenst work :(
X_Splinter posted 2008 Sep 05 13:20
Hi there.
I have a problem that never happend to me before.
I install Gordian Knot and cant rip nothing because the virtualdubmod.exe doesnt work, i even downloaded from the their site and still not work, simply nothing happens and i click on it.
I can run VirtualDub but i cant run VirtualDubMod
There must be something missing in my computor, i am using Windows XP SPK3.
Any ideas... please
gnandi posted 2008 Sep 06 13:25
Hi,
Same issue on my side also. XP SP3 too....
yoda313 posted 2008 Sep 06 15:24
reinstall it into a new directory. That should help. Make sure you have the latest version of vdub that you are trying to use also.
X_Splinter posted 2008 Sep 06 16:02
I downloaded vdubmod from its website, i extract it and still nothing happens when i double click it.
It was to be something concerning the service pack 3
Placio74 posted 2008 Sep 06 17:31
I'm have XP SP3 and not have problems with VDM and VD.
X_Splinter posted 2008 Sep 06 17:33
Placio74 :
Did you installed any additional NetFramework or something??? VD works fine but VDM doesnt.
In my other computors work fine, and worked with this computor when i had Vista installed. Now i Have Xp SP3 and doesnt work... Danm.... :cry: :evil:
Placio74 posted 2008 Sep 06 18:05
X_Splinter :
...Did you installed any additional NetFramework or something??? ...
Yes. .NET Framework 2.0 and 3.5 (because it's required by some apps - example meGUi and StaxRip).
I'm check VDM 1.5.10.2 (b2540 and b2542) also VDM 1.6.0 Surround (b2560).
Hmm... maybe try add to registry this:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Freeware\VirtualDubMod]
"VirtualDub"=dword:00000001
"SeenWelcome"=dword:00000001
"SeenMatroskaDeprecated 1.5.10.2"=dword:00000001
gnandi posted 2008 Sep 08 03:43
I've just tried all tips you gave:
- Reinstall to a new directory
- Registry tip
- Install .net 1.1 language pack
- Install .net 2.0
but none of these helped. And as I remember VDM worked fine on XP SP2 with .net 1.1 only.
Any more tips I could try?
Nandi
gnandi posted 2008 Sep 08 07:58
I have uninstalled all gordian knot related sw's, and installed the gk codec pack then the rip pack, and virtualdubmod is working fine... very interesting...
X_Splinter posted 2008 Sep 08 15:33
gnandi :
:shock: Really? So i am gonna try to do that...
X_Splinter posted 2008 Sep 08 16:21
I found the BUG :idea: :D
Its the FFDSHOW, this 2008 version sucks... I simply unistall it and voilá VDM works.
Someone should report this bug to them.
Anyway thank you guys for the tips :wink:
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
