VideoHelp.com forum archive
Tmpg-inc
Forum Archive Home -> Authoring (Blu-ray) -> Multiple AVCHD's to Single Blu-ray for PS3
hhel11 posted 2008 Jul 15 10:02
I had a quick question. I just bought myself the latest LG Blu-ray burner, and a bunch of single layer BD-R's.
I have on my computer a bunch of PS3 compliant AVCHD discs. I was wondering if there was any way/program that would allow me to take the M2TS files, after I extract them with tsmuxer, and re-author them into a blu-ray disc together. The files are all 1920/1080 and are encoded for playback on the PS3 so I cant imagine why it would not work. I just dont want to waste a $10 BD-R doing the wrong thing.
Any Help would be appreciated.
Btw- I'm not looking for anything fancy like menus, just one title after the other would do fine. And, I dont wish to just put the M2TS's in a data formated BD-R, I want it to be in the BDMV format.
Thanks,
Huck
musr139 posted 2008 Jul 15 10:17
If you do not care about menu etc, you could do this:
Use NERO Burning ROM DVD-ROM(UDF) choice, use the UDF tab to select UDF2.50
then simply drag all the xxxx.m2ts files to the compilation pane
and burn it.
Please try this test first using a DVD+R or some inexpensive disc before you do try BD-R so
you do not end up wasting the expensive BD-R.
I think it should do the job.
hhel11 posted 2008 Jul 15 13:06
I understand I can do that. Thats why I specifically said, is there a way to accomplish this, *not* merely making a data Blu-ray compilation. I wish to make a compliant BDMV, not just a data disc with a bunch of M2TS files on it.
Thanks, but, Anyone else?
t0nee1 posted 2008 Jul 15 13:29
So try with tsmuxer and create a Bluray structured disc....
http://www.afterdawn.com/guides/archive/convert_mkv_to_avchd_for_ ... lu-ray.cfm
Or read this,
http://club.cdfreaks.com/f142/backup-your-blu-ray-movies-guide-ba ... ay-208395/
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
