Forum Archive Home -> Portable Video -> MTP Device driver
MTP Device driver |
| a1i3n777 posted 2009 Feb 16 17:55 |
| Hello everyone
I was wondering if I install the mtp device driver, would I still need windows media player? The reason for this, is that I have a sansa view 8gb and I want to transfer music to it without having to use windows media player. this is the driver http://www.microsoft.com/downloads/details.aspx?familyid=FED98CA6 ... laylang=en |
| disturbed1 posted 2009 Feb 16 18:25 |
| Some devices have an option for either MSC or MTP. Check that first. I thought XP included the MTP driver?
The file you linked to is just the specification, not a driver ;) |
| a1i3n777 posted 2009 Feb 16 19:21 |
| Hmmm, Yeah it does have the driver installed, but a pop up window does not appear when I connect it. The manual says I need to install wmp, I guess it works as a handler or something to that extent.
I was just wondering if it was possible to work this without having to install it. |
| a1i3n777 posted 2009 Feb 18 09:09 |
| any suggestions? |
| disturbed1 posted 2009 Feb 19 05:26 |
| See if you can switch the device from MTP to MSC(UMS). I have several MP3 players, only one Sansa, most, including the Sansa e240 I own, do allow this in their settings. If not, try using google to search for an MTP compatible application. |
| a1i3n777 posted 2009 Feb 19 09:43 |
| yeah my sansa view does have this option. What I do is add the music to the music folder, but when I disconnect it, it starts to refresh and freezes... So the songs don't show up, but take up HD space on it. |
| disturbed1 posted 2009 Feb 19 16:38 |
| #1 result from google, First FAQ at sansa.
01. Sansa player freezes on the “Refreshing Database” screen STEP 1 – Reset the device 1. Slide the Power switch up and hold it for approximately 20 seconds. 2. Release the Power switch once the device is powered down. 3. Turn the device back on. STEP 2 – Download and Install the Sansa Firmware Updater. If this article did not resolve your issue, please contact us at support@sansa.com. http://www.google.com/search?q=Sansa+player+freezes+on+the+%E2%80 ... =firefox-a http://www.sansa.com/support/sansa_view/faqs |
| a1i3n777 posted 2009 Feb 19 16:47 |
| well my sansa is up to date... But let me try that out, and let you know. Thanks for that :) |
Login/Register to our forum to be able to post here.
