Forum archive - MEGUI MP4 to AVI XviD Error
http://www.supermediastore.com/
Forum Archive Home -> Video Conversion -> MEGUI MP4 to AVI XviD Error
DruidCtba posted 2009 Nov 01 10:31
Hi friends, I did had this problem and I don't know to resolved, please help me (This is ONE video but others videos the same problem) :( .
MEGUI Error:
[Error] Log
-[Information] Versions
--[NoImage] MeGUI Version : 0.3.1.1056
--[NoImage] OS : Windows XP Professional x86 SP3 (5.1.196608.2600)
--[NoImage] Latest .Net Framework installed : 2.0 (2.0.50727.0)
-[Information] Hardware
--[NoImage] CPU : Processador Intel Pentium III Xeon
-[Error] Log for job1 (video, AVISinth.AVS -> )
--[Information] [1/11/2009 12:20:54] Started handling job
--[Information] [1/11/2009 12:20:54] Preprocessing
--[NoImage] Job commandline: "C:\Arquivos de programas\megui\tools\xvid_encraw\xvid_encraw.exe" -i "C:\APE FLAC WV & AVI\MP4 & MKV & AVI HQ\AVISinth.AVS" -pass1 "C:\APE FLAC WV & AVI\AVI\Edit\Temp\AVISinth.stats" -bitrate 3200 -kboost 100 -chigh 30 -clow 15 -overhead 0 -turbo -max_key_interval 250 -nopacked -vhqmode 4 -closed_gop -lumimasking -imin 1 -pmin 1 -bvhq -bquant_ratio 162 -bquant_offset 0 -bmin 1 -par 1:1 -threads 1
--[Information] [1/11/2009 12:20:55] Encoding started
--[Error] An error occurred: xvid [error]: Bad Framerate 0.000000 (25/1)
--[NoImage] Standard output stream: xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003
--[NoImage] Standard error stream: Trying to retrieve width and height from input header
--[Information] [1/11/2009 12:20:55] Job completed
Video MediaInfo:
General
Complete name : C:\APE FLAC WV & AVI\MP4 & MKV & AVI HQ\###.BDRip.x264.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 1.51 GiB
Duration : 1h 27mn
Overall bit rate : 2 475 Kbps
Encoded date : UTC 2009-09-01 23:38:28
Tagged date : UTC 2009-09-01 23:38:28
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Duration : 1h 27mn
Bit rate mode : Variable
Bit rate : 1 944 Kbps
Maximum bit rate : 9 360 Kbps
Width : 720 pixels
Height : 304 pixels
Display aspect ratio : 2.35
Frame rate mode : Constant
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.370
Stream size : 1.19 GiB (79%)
Writing library : x264 core 68 r1183M f21daff
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=12 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=-2 / threads=12 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=1944 / ratetol=1.0 / qcomp=0.50 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=24000 / vbv_bufsize=24000 / ip_ratio=1.10 / pb_ratio=1.10 / aq=1:1.00
Tagged date : UTC 2009-09-01 23:40:03
Audio #1
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 1h 27mn
Bit rate : 132.3 Kbps
Maximum bit rate : 191 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 81.1 MiB (5%)
Encoded date : UTC 2009-09-01 23:39:23
Audio #2
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 27mn
Bit rate : 396 Kbps
Maximum bit rate : 517 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Rear: L R, LFE
Stream size : 247 MiB (16%)
Encoded date : UTC 2009-09-01 23:39:26
Thanks for advanced answers :) ,
Druid®
DruidCtba posted 2009 Nov 03 14:49
Oh no, no answer, please help me...
poisondeathray posted 2009 Nov 03 14:53
post your avs script
can you preview your avs script in vdub, or avsp?
DruidCtba posted 2009 Nov 03 14:55
My AVS script
DirectShowSource("My.File.mp4", fps=23.976)
poisondeathray posted 2009 Nov 03 14:56
Answer the 2nd question please, and report any error messages
I think your installed .net version is old too
DruidCtba posted 2009 Nov 03 15:04
Yes "No Errors" open with VirtualDUBMOD 1.5.10.2 & VirtualDub 1.8.6.
DruidCtba posted 2009 Nov 03 15:05
How to get it .NET and what Version to do Install?
poisondeathray posted 2009 Nov 03 15:07
If it previews fine, it's likely not an avisynth issue and I'm not sure then.
I think some of the xvid_encraw.exe versions had issues. You could use vdub to encode to xvid for now, or ask at doom9 forums where the developers could be found. You might try re-installing megui , or use a different xvid_encraw version. The latest version of .net framework is 3.5, and you can find it from microsoft, but I don't think that's your problem
Can you encode using x264 in megui? If you can successfully with the same script & setup, that suggests an issue with xvid_encraw
DruidCtba posted 2009 Nov 03 15:10
I reinstall MEGUI twice and NOTHING, the same error...
Please, what .DOTNET to do install?
P.S This error occurs with .MKV files too... and I don't know used VBUD to do this work.
DruidCtba posted 2009 Nov 03 15:11
How to know my versin .DOTNET and what .DOTNET version MEGUI work?
DruidCtba posted 2009 Nov 03 15:12
I would like to do job with MEGUI, please help me...
poisondeathray posted 2009 Nov 03 15:15
Your log file reports it
I have 3.5 installed, xvid_encraw 2009-06-05 1.3 VAQ, and it encoding with xvid works fine
If your error occurs with x264 and mkv too, then you have bigger problems
You could try xvid4psp to encode to xvid/avi, or use a guide for vdub on how to encode
DruidCtba posted 2009 Nov 03 15:19
I don't understood MICROSOFT DOT NET have versions 1.x, 2.x ans 3.x, but anything program work with 1.x and not 2.x or 3.x and so on, then why install MEGUI do not see ERROR for DONET?
DruidCtba posted 2009 Nov 03 15:20
Please ANYBODY help me to SOLUTION, please.
Ai Haibara posted 2009 Nov 03 15:46
First, make sure your .NET installations are completely up-to-date. Run Windows Update and install any updates/service packs for whatever .NET versions show up.
For the most part, the .NET frameworks are NOT backward-compatible or cross-compatible. If you have a program that wants .NET 1.x to run, it won't run with .NET 3.x - you'll need to install the version the program wants. To add even more problems, I've been hearing that .NET 4, which is in development, isn't compatible with some of the older .NET versions and will ask you to uninstall them.
From the MeGUI FAQ:
What version of the NET framework can I use?
Versions 2.0 and 3.0 should work.
But is this really a .NET issue?
DruidCtba posted 2009 Nov 03 15:48
I get it xvid_encraw.exe 2009-06-06 1.3 VAQ and replace in MEGUI install
Now ERROR:
[Information] Log
-[Information] Log for job1 (video, AVISinth.AVS -> )
--[Information] [3/11/2009 19:44:53] Started handling job
--[Information] [3/11/2009 19:44:53] Preprocessing
--[NoImage] Job commandline: "C:\Arquivos de programas\MeGui\tools\xvid_encraw\xvid_encraw.exe" -i "C:\APE FLAC WV & AVI\MP4 & MKV & AVI HQ\AVISinth.AVS" -pass1 "C:\APE FLAC WV & AVI\MP4 & MKV & AVI HQ\AVISinth.stats" -bitrate 3200 -kboost 100 -overhead 0 -nopacked -closed_gop -par 1:1 -threads 1
--[Information] [3/11/2009 19:44:55] Encoding started
---[NoImage] Trying to retrieve width and height from input header
---[NoImage] Wrong input format, I want YUV encapsulated in PGM
--[Information] [3/11/2009 19:44:56] Job completed
DruidCtba posted 2009 Nov 04 16:22
Please people, I need one HELP.
Ethlred posted 2009 Nov 05 00:19
What is your source?
Things to try.
Install the latest .Net. Don't bother wasting anymore time till you install the latest version. Not the 4.0 beta. I think its 3.5. .Net has several versions and they mostly play nice with each other. Programs use the version they are supposed to, at least if that version is installed.
I just checked the Megui site and it says it uses .Net 2.0 but that page hasn't been updated in over a year.
I suspect that the 4.0 has compatibility issues only because its a beta, so leave it alone.
Once you have than try again.
It is possible that your source is the problem. Most encoders expect, I think its YUY2, which is what MOST DVDs have. But some do not have that and then you will may have to ad a color space conversion to the AVS script.
Try another source if this is the only thing you have tried with MeGui. If another source works then its likely that the source is the problem.
The catch here is that MeGui is having problems at the moment. A lot of changes recently in X264 and some of the people that work on MeGui have disappeared for a while. You are using the same version as I am and its working for me, but I am using X264 not Xvid. I checked and I think you have the same version of Xvid but I haven't tested whether it works properly as I stopped using Xvid some time ago.
There are some work arounds I have had to use with MeGui at present. I find that I have to shut down Megui to get any profile changes to stick. They aren't saved till exit for some reason. In X264 I also had to uncheck - Keep some B-Frames as reference. Never really liked that anyway. It messed up the older Nero Showtime I have. Apparently some hardware players don't like it either.
I checked the color space in a couple of DVDs by using Media Player Classic
- Right click while playing
- Filters
- Video Mixing Renderer
- Pin Info tab
If it doesn't say YUY2 then that is the most likely cause of the problem.
Ethelred
DruidCtba posted 2009 Nov 05 12:08
Hi friend Ethlred the Media Player Classic Pin Info tab is:
Filter : Video Renderer - CLSID : {B87BEB7B-8D29-423F-AE4D-6582C10175AC}
- Connected to:
CLSID: {9852A670-F845-491B-9BE6-EBD841B8A613}
Filter: DirectVobSub (auto-loading version)
Pin: Output
- Connection media type:
Video: YV12 1024x304 (45:19) 23.98fps
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71}
subtype: MEDIASUBTYPE_YV12 {32315659-0000-0010-8000-00AA00389B71}
formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 466944
cbFormat: 1152
VIDEOINFOHEADER:
rcSource: (0,0)-(720,304)
rcTarget: (0,0)-(720,304)
dwBitRate: 0
dwBitErrorRate: 0
AvgTimePerFrame: 417083
VIDEOINFOHEADER2:
dwInterlaceFlags: 0x00000000
dwCopyProtectFlags: 0x00000000
dwPictAspectRatioX: 45
dwPictAspectRatioY: 19
dwControlFlags: 0x00000000
dwReserved2: 0x00000000
BITMAPINFOHEADER:
biSize: 40
biWidth: 1024
biHeight: -304
biPlanes: 1
biBitCount: 12
biCompression: YV12
biSizeImage: 466944
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
pbFormat:
0000: 00 00 00 00 00 00 00 00 d0 02 00 00 30 01 00 00 ........Ð...0...
0010: 00 00 00 00 00 00 00 00 d0 02 00 00 30 01 00 00 ........Ð...0...
0020: 00 00 00 00 00 00 00 00 3b 5d 06 00 00 00 00 00 ........;]......
0030: 00 00 00 00 00 00 00 00 2d 00 00 00 13 00 00 00 ........-.......
0040: 00 00 00 00 00 00 00 00 28 00 00 00 00 04 00 00 ........(.......
0050: d0 fe ff ff 01 00 0c 00 59 56 31 32 00 20 07 00 Ðþÿÿ....YV12. ..
0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0070:|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0200: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0210: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0220: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0230: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0240: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0250: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0260: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0270: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0280: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0290: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
02a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
02b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
02c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
02d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
02e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
02f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0300: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0310: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0320: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0330: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0340: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0350: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0360: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0370: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0380: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0390: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
03a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
03b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
03c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
03d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
03e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
03f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0400: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0410: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0420: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0430: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0440: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0450: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0460: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0470: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Thanks for all
DruidCtba posted 2009 Nov 05 12:16
Oh the video is: The.ONE.[2001].BDRip.x264.[English].by.Wrath.mp4
Thanks for help me.
In MEGUI is possible change downscale 1024x534 to 720x308 (2.35 aspect ratio)?
DruidCtba posted 2009 Nov 05 12:30
Hey what's happening:
MPC
Media Info
Width : 720 pixels
Height : 304 pixels
This is a problem with MEGUI or NOT, I don't understand....
DruidCtba posted 2009 Nov 06 11:57
And ?????????????
Baldrick posted 2009 Nov 06 14:35
Buy it instead of downloading warez.
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
