Forum archive - Media Center won't connect to TV through HDMI
http://www.supermediastore.com/
Forum Archive Home -> Media Center PC / MediaCenters -> Media Center won't connect to TV through HDMI
Rob.T posted 2009 Sep 07 17:17
I recently entered the wonderful world of HDTV when I bought a Samsung LN37B530. I then purchased a WD TV HD Media Player which was simply AMAZING! However, for some reason I can no longer connect my TV with the Media Player through an HDMI port! The TV simply says there "no signal". :x There are 3 HDMI ports on my TV: none will work with the WD Player. I also have 2 HDMI cables - a 6' and a 10': neither works with the WD. Both cables & all 3 ports work with my blu ray player. I did have a 4' HDMI cable which worked with the Media Player, but I traded that away. I have updated the firmware for both the TV & the WD player - no joy. The WD Player works with the RCA composite Jacks, but really, what's the point? Is there some limit on the length of HDMI cable that the WD Player will be able to accomodate? Or is it my TV?
Thanks!! :roll:
ktnwin posted 2009 Oct 01 17:39
You may want to contact WD for support.
stiltman posted 2009 Oct 01 18:47
Had the same problem
I connected via composite
Changed the HDMI settings to the lowest
Reconnected the HDMI
then the signal came through.
Then I manually upped the quality one tick at a time.
redwudz posted 2009 Oct 01 19:06
I had a similar problem to stiltman's and basically did the same thing. HDMI is a 'handshake' protocol and both units have to agree or it doesn't work. :( Check your WD/TV settings.
I use a 45 foot HDMI cable to my projector, so cable length is likely not an issue for you. If all that fails, then maybe the WD HDMI port died. :(
Login/Register to our forum to be able to post here.
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
