VideoHelp.com forum archive
http://www.supermediastore.com/
Forum Archive Home -> Linux -> Mandriva - apt-get or zypper equivalent?
kenmo posted 2008 Jun 12 13:53
Anyone know what the Mandriva equivalent for Debian's apt-get or Suse's zypper command is?
joeboomer628 posted 2008 Jul 23 22:01
Mandriva uses a program similar to SuSE's yast2 for configuration and software management. Packages are RPM's so they can be manipulated with RPM tools. I think the configuration program is called Drakconfig or something similar.
courtrrb posted 2008 Jul 27 17:03
It's called urpmi. Go to http://easyurpmi.zarb.org/ to set it up. Once done you need to load anything else
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
