Forum Archive Home -> Editing -> Major Help with Video Quality issues
Major Help with Video Quality issues | ||||||
| Deter posted 2009 Oct 29 17:19 | ||||||
| Hello,
I have loads of stuff on VHS and DVD that I am trying to play back on my PC and internet with the best possible quality. Some stuff is PAL other is VHS, some are digital DVD recordings I really haven't had any help with any of this, I just kind of do things by guess work.... I have 3 Video programs on my PC 1) Window Movie Maker 2) Sony Vegas 9.0 3) MAGIX EDIT PRO 15 Everytime I try to use one of these programs and do a simple edit to a video, aka fade out, when I go to save the file or re-rip the file the quality is downgraded big time. I usually do WMV file, the quality seems better on my PC...No idea what format is the best..I think MP4 or MPEG4 are Crap...... These are the setting I have been using for my videos 1440x1080 (Full Screen) Usually old VHS stuff 720x480 (Full Screen or Letterbox) 720x576 640x480 QUESTION#2 To edit the videos I basically record from DVD player to DVD player or VHS player to DVD player. Or DVR to DVD player.... Because HD recorder are not out, I use my DVD recorder to Record HD broadcasts, the stuff is letterbox and never full screen. So I record from the source and the quality is really good. Next I will play the disk back and go in and make edits. I than have to do this a few times. By the 4th or 5th time the quality starts going to crap. The screen gets a tad blur and some distortion is present, if I have to run through lets say 10 dvd's trying to edit and fix up a video, by the end the quality is not the best....It is still better than using the PC blur vs choppy My Recorder is a Panasonic DMR-EZ27 The DVD player is Samsung DVD-HD860 My goal is to make the best possible recording, what do I need to do? | ||||||
| Soopafresh posted 2009 Oct 29 19:18 | ||||||
| Post a before and after pic of a frame | ||||||
| Deter posted 2009 Oct 29 20:09 | ||||||
| You really need to watch the videos....I am kind crazy when it comes to details..
It is like this, when u edit the video using the computer, it almost skips frames. So if you were filming a bird flying... Before the edits it would look like it was flying after any computer edits the bird would skip frames and it would not look natural and give u a headache... On the 1st recording it would look perfect by recording number 10 the bird would look like a blur in places.... On a specific frame it would look kind of close....Any kind of action or movement u could see the difference in two seconds...... | ||||||
| jagabo posted 2009 Oct 29 20:13 | ||||||
No. You're doing something wrong. First of all, forget WMM unless you are making streaming web videos. Even then, use it only as the very last step in your processing. You should avoid multiple generations of video capture. Capture once, make all your edits, save the results. Vegas has a smart MPEG2 editing mode that should allow you to do this without reencoding, except a few frames around cut GOPs, or unless you're filtering. No reencoding means no loss of quality. It's pointless to use 1440x1080 for VHS. Capture NTSC VHS at 720x480 or 352x480. That's all the resolution it has. | ||||||
| Deter posted 2009 Oct 29 22:30 | ||||||
| jagabo, it may seem pointless however the quality of the picture is amazing. It is so much better than the original take.
I don't use MPEG2 or MPEG4 cause I feel the picture quality is not good...The file are small and it compresses the data...Like I said I am weird and it is all about the details.... | ||||||
| jagabo posted 2009 Oct 29 22:54 | ||||||
That's still capturing as far as I'm concerned.
That's exactly what you should be avoiding. All those analog/digital conversions are causing your problems.
Then you need to invest about US$1000 in equipment. An s-vhs deck with line tbc and noise filtering, a full frame tbc, and a video proc amp. If you want to stick with your DVDR caps, capture once to DVDR, export the MPEG 2 data from the discs, then edit them in Vegas. That will get you far better results than several consecutive generations of DVD caps. | ||||||
| Deter posted 2009 Oct 29 22:55 | ||||||
| Any advise on improving the video quality using the computer edit programs? |
Login/Register to our forum to be able to post here.
