Forum Archive Home -> DVD Recorders -> Magnavox MWR10D6 timer overwrite?
Magnavox MWR10D6 timer overwrite? |
| davidrome posted 2009 Sep 26 20:54 |
| I've searched but couldn't find similar topic. I've searched the instructions and fiddled with the machine (great basic recorder for the price, had it 1-2 years), but can't find it anywhere. Can you not use timer recording on the Overwrite feature??? Just as you used to wear out a VHS tape by recording over and over that same show each week while you were gone, it makes sense you should be able to do the same here. If you know the machine, it only mentions the "as you stand there" overwrite recording feature. I'm using way too many discs. Thanks!! |
Login/Register to our forum to be able to post here.
