Forum Archive Home -> DVD Recorders -> lite-on LVW-5045
lite-on LVW-5045 |
| pmitch posted 2009 Mar 17 04:53 |
| Can anyone out there tell me if my Lite-on LVW-5045 will automatically change time setting when British Summer Time comes in next weekend?
If not, I will have to adjust my recording times to suit the change in the real time!!!!! Am going away tomorrow so this request has some urgency and would be very grateful for any knowledgable responses. Ta. |
| CrazyCanuck posted 2009 Mar 17 17:29 |
| Hi pmitch, the 5045 doesn't support time changing, you need to go into setup and change the clock manually on the day(s) time changes occur. You don't need to change your timer settings, just your clock.
I suspect the question is that you'll be away when the time change occurs, then absolutely, you need to change your timers. It's a PITA to have to change them all back and adjust the clock when you come back but that's basically your only option with the 5045. |
| pmitch posted 2009 Mar 18 04:44 |
| Thanks,
you are a star! |
Login/Register to our forum to be able to post here.
