Hello,
I have spent almost 2 hours of looking though the different questions people have about their LG LRA-780, I couldn't find anyone with the same problem as me.
Problem:
I want to transfer some recorded TV to a DVD-R or RW or really anything! I can record to disk however I'm only able to watch on the original DVD player. I have tried to finalize the disk without success. I have figured out that the disk requires that it be initailized in order to finalize. When going through the steps outlined in the instruction book, I am not able to "choose" initialize disk. The option is not "highlighted" so I can not choose to do that function.
Does anyone know what I might be doing wrong?
Was I suppose to "do something" before I started recording on the HDD?
Please any suggestions would be appreciated!
I have an LRH-780, which should be similar to your model. Although the manual describes how to format a blank disc, the recorder actually does it automatically as soon as I insert a blank disc. DVD-RW's are auto-formatted in VR mode, and all others are in Video mode, so if I prefer the -RW in Video mode, I re-format as follows:
"Setup - Disc Format - Video mode".
Finalizing seems to be automatic as well: Just turn the recorder off at the conclusion of recording to the disc, and it takes about a minute "Preparing a menu" before it shuts off. If I intend to play the disc on another player, I go to "Setup - Finalize Disc" prior to turning the recorder off, but I'm not sure this is necessary for -R /+RW discs.
Note, however, that even the finalized discs won't play on a couple of cheapie stand-alone players that I wasted my money on.
I hope this helps. -
You have to choose DVD on the HDD/DVD setting (either use the HDD/DVD button on the machine, or there's separate HDD DVD buttons on the remote). This will enable you to format/finalize the DVD. Kind of frustrating, but ...
For temporary stuff, I recommend using +RWs, if your other players can play them. DVD+VR is a more convenient format. It automatically finalises when you eject the disc (although you have to switch the HDD/DVD to DVD before you can eject).
BTW, I believe your machine is LRH-780, H being (I assume) HDD. All the A models I've seen are disc only recorders. -
Thank you...your right it is LRH-780, and I can't claim fat fingers as A and H are 4 keys apart!
I will try the suggestions of switching to DVD using the DVD/HDD button. I will let people know if it's that easy!
Thank you again!
tnk -
obs was right
Thank you very much! -
I am having similar problems. I can transfer the files from my LRH-780 hard disk to a DVD-RW. Once on the DVD-RW, I can play them on the DVR. My problem is that I want to import the video onto my laptop using Adebe Premiere Elements. The program recognizes there is a file on the DVD but I can not get the video images.
Alan
How do you re-format a BD-RE disk??
By EagleW in forum Authoring (Blu-ray)Replies: 2Last Post: 16th Apr 2010, 19:50 -
LG LRH-780 harddrive upgrade
By canadian bacon in forum DVD & Blu-ray RecordersReplies: 44Last Post: 24th Oct 2009, 03:03 -
Problem with LG LRA-750
By polus in forum DVD & Blu-ray RecordersReplies: 0Last Post: 31st Mar 2009, 16:46 -
remove H.264 for MVIX 780
By octorfish in forum ffmpegX general discussionReplies: 1Last Post: 5th Sep 2008, 12:42 -
Recording Times with the LG LRH-780
By Battisti in forum DVD & Blu-ray RecordersReplies: 8Last Post: 3rd Nov 2007, 00:13
