VideoHelp.com forum archive
Tmpg-inc
Forum Archive Home -> Media Center PC / HTPC -> laptop playing dvd problem
ieh4f posted 2008 Jun 17 14:56
my laptop lags/pauses for 1-3 seconds every 40 minutes when l play dvd movies in it, what is the problem? l am using vista home basic
Baldrick posted 2008 Jun 17 15:15
Have you checked the windows scheduler/antivirus tool/etc and see if something runs every 40 minute?
redwudz posted 2008 Jun 17 15:23
Playing them from the DVD drive? How much RAM do you have? One gigabyte of RAM is about minimal with Vista, two is better. Did the laptop come with Vista installed? What program are you using for playback?
I would take a look at your Task Manager and see how much CPU power and RAM it's using at the time of the problem. That may give you a clue. Also, if you are using a DVD disc, try ripping one to the hard drive and play back from there and see if that works better.
Ai Haibara posted 2008 Jun 17 15:27
Don't a lot of laptops these days also used shared memory? That might also make working with Vista on a laptop fun, unless you do have 2GB of RAM.
ieh4f posted 2008 Jun 17 17:10
l am running celeron m 2G with 2038mb ram, task manager says cpu is under 20% and ram under 1000 mb, ripping one to the hard drive just like pricacy, why bothering buying the disc?
ieh4f posted 2008 Jun 17 17:16
and l am using compaq/hp dvdplay and window media player, and yes it comes with vista installed, and how to open windows scheduler?
redwudz posted 2008 Jun 17 21:37
I'm using a Compaq F750 lqptop with Vista Home Premium at present. But Scheduler is in 'Control Panels>Administrative Tools'. There is also a event viewer there.
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
