Forum archive - Jitter playback on DVD player
http://www.supermediastore.com/
Forum Archive Home -> Video Conversion -> Jitter playback on DVD player
Mylo posted 2009 Apr 30 20:38
I done some video in AE, short 30 second clip.
Rendered it to AVI without any compression, and then converted it via TMPGEnc to MPEG-1 format, constant bitrate on 7000 kbps.
And when I playback it on DVD player it skips, the format is fine, aspect ratio is fine, but the playback is jitterish, as if i it was made at 12 fps.
3 questions
1 - is the bitrate too high for smooth DVD playback?
2 - would it be any better if I converted it to VOB?
3 - should I convert it to MPEG-2 format which offers me interlace option (this one was rendered progressive)
Chris K posted 2009 Apr 30 23:12
For standalone DVD player playback, mpeg1 bitrate is far to high. The DVD specs say max 1280 kbps.
I would convert to mpeg2 which should also allow to use progressive source. Then 7000 kbps is fine.
Krispy Kritter posted 2009 May 05 13:08
All specs listed here: (upper left pane - WHAT IS - DVD)
http://www.videohelp.com/dvd
ckbasak posted 2009 Oct 29 05:01
I have made MPEG2 file (.mpg) and copied it to USB drive. When playing it in my standalone DVD player, the video jitters (looks like slow motion with very low fps). I have tried with 6000kbps, 3400kbps, 2000kbps. But the result is same. Even with 2000kbps video quality is blocky also.
What is wrong? I am using Pinnacle Studio 12 Ultimate.
jagabo posted 2009 Oct 29 07:21
Many players will not play "bare" MPG files properly -- it's not required by the spec. Author a movie DVD with IFO/VOB files.
Other possible problems if your DVD player can play bare MPG files:
The player may only have a USB 1.1 port, not USB 2.0. So it simple can't read data off the drive fast enough. Write it to a DVD instead.
The drive itself might be too slow. This isn't likely with a hard drive but some flash drives have very low read/write speeds.
Login/Register to our forum to be able to post here.
DVDFab DVD to DVD and Blu-ray to Blu-ray offers a 20% discount until Nov 22, 2009. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
