Forum archive - Is multiavchd a problem?
http://www.supermediastore.com/
Forum Archive Home -> Authoring (Blu-ray) -> Is multiavchd a problem?
volam1 posted 2009 Oct 04 12:53
I already had 1 post for my problem. I hope the author of multiavchd can see this new post and give me some help.
I used multiavchd to author some videots and avi files to blu-ray player, which then was burned onto bd-re 25gb ver2.1 using Imgburn. but my magnavox nb500mg9 did not play the content because it is not compatible. I think there are only 3 links of this chain:
1/ the bd player: I already checked the manual. this player can play bd-re ver.2.1 with the content recorded in bdmv format. So, this link can't be a problem.
2/the disc: I used a brand new bd-re ver. 2.1 25 gb out of the box, made in japan. the burning process was confirmed successfully. this link can not be a problem either.
3/the software/tool: Unfortunately I have to think this may be a problem.
I have worked with other formats/tools and I notice that sometimes the software/tools do not perform as the are described. I do not know whether multiavchd has this kind of problem or I did not use it correctly.
all responses will be appreciated very much.
Baldrick posted 2009 Oct 04 15:19
One similar topic is enough. Just reply to add new information. http://forum.videohelp.com/topic373871.html
Login/Register to our forum to be able to post here.
Replay Media Catcher lets you record ANY streaming video and save on your computer! More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
