Forum archive - Installation error -
http://www.supermediastore.com/
Forum Archive Home -> ffmpegX bugs and suggestions -> Installation error -
ruggerjvd posted 2007 Jan 01 12:12
I searched for an answer to this, but it was not addressed. I am trying to install v. 009k on a laptop. I downloaded the files and stored them in a folder called "ffmpeg binaries" in the applications folder. I selected all the files in the installation directory, but I get the following error message:
##/bin/sh: line 1: cd: /usr/local/include: No such file or directory
Is it because I am trying to install an older version of ffmpeg?
thanks for the help
tomlee59 posted 2007 Jan 02 04:05
If that directory is really called ffmpeg binaries, and not ffmpeg_binaries or some such thing, that's your problem. The installer is fussy about special characters (and that includes spaces) in the pathname. This is a very common problem.
Case posted 2007 Jan 02 20:50
http://forum.videohelp.com/viewtopic.php?t=315496
theomike posted 2007 Nov 04 20:03
I have a similar problem when trying to do the _required_ update of ffmpegx.
The Self-Installer doesn't see the binaries at all(!) in the ffmpegx folder I placed them in!
The instructions do say the hard drive can't have spaces, well how can I change that without losing anything else that relies on the traditional "Macintosh HD" (space, no underscore)?!
The application is now useless, and I have come to depend on it!
HELP!!!
Case posted 2007 Nov 12 09:06
theomike :
Place your three binary files on the desktop. Use the Locate button to point the installer to them. The paths then become
/Users/username/Desktop/mpeg2enc
/Users/username/Desktop/mencoder
/Users/username/Desktop/mplayer
which might be enough to make it work, as the volume name now isn't part of the path.
The binaries are copied by the installer, so the original files can be removed afterwards.
theomike :
You could try changing the boot volume name, install the binaries, then change it back to what it was. Worth a try, don't you think?
Login/Register to our forum to be able to post here.
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
