| Nintendo Fan posted 2008 Oct 18 14:39 |
| poisondeathray : |
| Did you put the mov plugin for vdub in the plugins folder (or plugins32 folder)? |
Idk how to do that :shock:
| redwudz : |
EDIT: No real reason to delete your post, but I will tell you your signature is in violation of our rules: http://forum.videohelp.com/topic124514.html Scroll down to the signature size rules.
Please correct this.
Moderator redwudz |
Ok I'll change it. Thx for telling me.
| redwudz : |
The latest versions of VD should accept .mov video if you add the plugin: http://download.videohelp.com/download/Quicktime_VD_v0.2.0.0_bin.zip
But a simple AVISynth script should also work. I use that method to edit RM video with VD. You can also frameserve the .mov to other encoders. AVISynth may be a bit daunting to start with, but with simple scripts, it's a very powerful program. For your types of video, well worth looking into. :)
One AVISynth guide: http://forum.videohelp.com/topic284288.html There are many more at the bottom of the AVISynth toolpage.
You might also try a simple payware converter like ConvertXToDVD. It accepts quite a few formats and outputs as a DVD. |
:shock: I have no idea wat the hell "frameserving" is, or how to do it... :o
| Nintendo Fan posted 2008 Oct 18 14:41 |
.....Can someone explain to me why I can't reply to my thread in the "Video Conversion" forum??? I keep getting "Internet explorer cannot display the web page" when I submit my post?
