Forum Archive Home -> Mac -> How to set streaming audio input to Audacity?
| How to set streaming audio input to Audacity? |
| edDV posted 2008 Aug 24 18:11 |
| On weekends I like to record tech streaming radio broadcasts (e.g. Leo Laporte on KFI) to Audacity and this works fine on my PC laptops (XP or Vista).
I want to use my Mac as an alternate recorder. First I installed Flip4Mac WMV to get WMV streaming support into Qucktime and can hear the broadcast fine. Next I installed the Mac version of Audacity but can't connect to the stream for recording. Anyone know how? I had to struggle with Vista audio into Audacity and solved that, how do I do it on an Intel Mac? |
| tomlee59 posted 2008 Aug 25 03:56 |
| Audacity works a bit differently under Mac OS than under XP/Vista. You'll need another app to enable capture. Audio Hijack is one.
See http://audacity.sourceforge.net/help/faq?s=recording&i=streaming for additional info about this topic. As you can tell, it's one of the more popular questions. Good luck! |
| edDV posted 2008 Aug 25 13:19 |
| Thanks for the tip. |
Login/Register to our forum to be able to post here.
