Forum archive - How long does it take to Burn a Blu-ray?
http://www.supermediastore.com/
Forum Archive Home -> Authoring (Blu-ray) -> How long does it take to Burn a Blu-ray?
DGenerateKane posted 2009 Sep 06 03:25
How long does it take you guys to rip/compress/burn a blu-ray? I know it varies between systems but I'm just looking for an average. Thinking of building a new PC just for faster speeds if it would be significant (Currently running an antiquated p4 2.6 OC'd to 3.1 with only 1 GB RAM). So, how long to rip a dual layer disc and compress/burn it to a single layer disc?
redwudz posted 2009 Sep 06 05:01
The only procedure that's really related to PC speed is the compression process. It takes me about five hours to convert a 25GB+ BD disc to a 7.95GB DL MKV data disc using RipBot. That's on a quad core 3.6Ghz computer. When I used a 2.5Ghz quad core, conversions took about six hours or so.
Ripping takes whatever time your BD drive takes to read the disc, 40 - 50 minutes. Burning a disc is the same, whatever your burner speed/media speed is. If you are burning directly to BDRW, just takes the ripping time and burning time if the movie will fit directly on a BD disc. ImgBurn can do that.
You also asked about DL>SL disc conversions? I use DVDShrink for that after decrypting. Shrink takes about a half hour or less, depending on the DVD source size, for the whole process.
The amount of RAM you have doesn't have much bearing on ripping, converting or burning. But I use 2GB for XP and 4GB for Vista. With these type of conversions, especially to H.264 (MKV), a fast quad core will help considerably to shorten encoding time.
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
