Forum Archive Home -> Computer -> How do I remove/block Flash ads?
| How do I remove/block Flash ads? |
| videohalp posted 2008 Sep 26 15:30 |
| Using Firefox.
Removing the Flash plug-in is not an option since I frequent YouTube. The only way I know of how to block the Flash ads is installing a plug-in that requires JavaScript. But with JavaScript enabled, the JavaScript ads would kick in instead. Is there a way I can get Flash to be enabled only in YouTube and disabled for all else? Or something similar to that. |
| Baldrick posted 2008 Sep 26 15:49 |
| Firefox and http://addons.mozilla.org/en-US/firefox/addon/10 |
| jagabo posted 2008 Sep 26 17:36 |
| I use an old version of Internet Junkbuster that I modified. When I hold down the left control key the filtering is bypassed. I block all SWF by default. If I want to see a Flash video I just hold down the control key and refresh. |
| freebird73717 posted 2008 Sep 26 17:43 |
| Flashblock
Blocks all flash and replaces it with a little "f" symbol. If you want to view that particular flash just click the little "f" |
| Ai Haibara posted 2008 Sep 26 19:45 |
| NoScript also blocks Flash, as I recall. You can have it block everything, so to speak, and then just whitelist YouTube. |
Login/Register to our forum to be able to post here.
