Forum archive - How do I hook up Hotronic ap41 to my VCR?
http://www.supermediastore.com/
Forum Archive Home -> Restoration -> How do I hook up Hotronic ap41 to my VCR?
DaneClark posted 2009 Nov 03 12:15
I just bought one off ebay and I can't figure out how to hook it up. The Composite cables won't fit in the plugs in the back, and the composite plugs look like a completley different kind of plug than the ones in the back of my VCR (my VCR is a Samsung DVD-V6700 DVD/VCR combo)
hech54 posted 2009 Nov 03 12:33
A simple Google search shows it has BNC connections.
orsetto posted 2009 Nov 03 12:35
All professional gear uses "BNC" twist-lock connections for composite video. Go to Radio Shack and pick up a little BNC-to-RCA adaptor, it fits right over the Hotonic connector and converts it to a standard RCA jack. You could also use a cable with BNC plug on one end and RCA plug on the other.
DaneClark posted 2009 Nov 03 15:33
Okay, I used a BNC-to-RCA Adapter to connect the TBCs BNC Video Out to the VCRs Line 2 Video In, but I don't see any difference in the video playback
Login/Register to our forum to be able to post here.
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
