Forum archive - How do I add subtitles to a series?
http://www.supermediastore.com/
Forum Archive Home -> Subtitle -> How do I add subtitles to a series?
Desman posted 2009 Nov 03 02:24
I have the original dvds but my language is not in the subtitles.
I am using SubtitleCreator.
DVDs are copied to hd and all subs episode 1-12 are converted to .sub
It is fairly easy to add one set of subs, but how do I add more than one episode of subtitles to the 'menu' ?
/Desman
manono posted 2009 Nov 03 03:08
Assuming each episode has its own Title/PGC, then you add them to all the episodes the same way you added them to the first episode. If all the episodes are in the same Title/PGC, then you have big problems, but that's fairly rare.
Is this for DVD? If so, did you read the sticky just above where you posted?
http://forum.videohelp.com/topic267417.html
What's the menu have to do with adding subs to the episodes?
Login/Register to our forum to be able to post here.
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
