I want to replace my old HDD to a new one, I record the ID on back of machine (just below the RF jet) EJDL004013LY; than I enter the ID setup page from service remote, I found the numbers are different (at this moment I was so fool and forget to write down this digit...); than I follow the step press esc + stereo + 9;
now everytime I turn on my DVR it said CPRM error and than HDD error (I am connecting my original HDD). Is there any way to retrieve my 9 digit ID??
Results 1 to 13 of 13
From what I can tell. This is not your recorder ID. There should only be 9 numbers. Not 11 characters mixed with numbers and letters. And it should be numbers only.
My guess would be to hit ESC+Stereo. Then, look to see if the original number is still listed on the screen, if it is, write it down. If it's not, then you need to locate it on the recorder somewhere. Usually on the back somewhere. If it's not there, then you might have a problem.
If this is the case, I would have to defer to one of the others here that might have more knowledge than me. Perhaps they can assist better in locating a number that has dissapeared.Yeah, I'm probably nuts... But what the hell. Nobody's perfect. -
Originally Posted by Bagheera
I am blessing God can help me -
Originally Posted by stepwWhen in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form.
Hi bros, I try a fake CPRM ID from faq guide: 001296784 and it works now, even I can record and playback on my new HDD.
But everytime I will have 'wrong HDD info' err msg during power on. Looks I got to UG my firmware but I need some advise before doing stupid things again
Any suggestion?
PS. I attach my ver info find from service remote page, hope some expert can help.
Looks I did stupid thing again... I download the 630H firmware and update.
After that I dont have any HDD err msg anymore, but I can't gain control by my remote control. Once it enter 'home menu' I can't quit it, I can control the up/down but just can't press enter nor quit (I have to do power reset than...)
From service page it seems err on IRCON, it show NG-... service manual ask me to download firmware but where can I find the suitable one?
Mind DVR is 630-HS while official pioneer website only got 630H...
You did use a totally wrong firmware for your DVR, you used the firmware that is from Pioneer Europe.
Check your PM! -
I figured someone with more knowledge would come along eventually. There are some very smart people out here that know a hell of a lot about these machines. I hope you get your unit fixed.
thanks bros, after consult with Hkan I fix my machine. (I was upgrade with a wrong firmware but lucky Hkan got a correct one.)
Now I am enjoying my new 250GB HDD -
Hi, I also lost my ID number. I am trying to replace my HDD and getting ID NG on the unit itself and Write wrong NO!on my TV. I have a Pioneer 533H-S(Canada). I have obtained the right firmware but the first time I went in with the Pioneer Service remote I did not have the Data Disk GGV1256 and I stopped in the middle of installation. I did not notice the very first time what the ID number was as it looked to me to be the same as the one written on the back of my unit which is the one I am using and getting the messages noted above.
Is there a way to obtain another ID number?
Regards,Last edited by claprade; 14th Jan 2012 at 22:47. Reason: I should of used a new post
Is there a way to obtain another ID number? Hopefully this will solve my problem.
Regards, -
Lost my ID number. I am trying to replace my HDD and getting ID NG on the unit itself and Write wrong NG! on my TV. I have a Pioneer 533H-S(Canada). I have obtained the right firmware but the first time I went in with the Pioneer Service remote I did not have the Data Disk GGV1256 and I stopped in the middle of installation. I did not notice the very first time what the ID number was as it looked to me to be the same as the one written on the back of my unit which is the one I am using and getting the messages noted above.
Regards,
Hard Drive upgrade for Pioneer DVR-530/630H
By Hkan in forum DVD & Blu-ray RecordersReplies: 55Last Post: 22nd Aug 2012, 01:07 -
Pioneer DVR 630H - 640H
By justmehere2010 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 29th Jun 2010, 13:58 -
When and how did the four digit file extension enter the MS world?
By yoda313 in forum ComputerReplies: 4Last Post: 20th May 2010, 23:07 -
3 Digit manufacturer's code for Toshiba SD-V395KC
By Snakebyte1 in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2009, 10:15 -
DVD-burning problems (Pioneer DVR-630H)
By tigrr in forum DVD & Blu-ray RecordersReplies: 7Last Post: 9th Jan 2008, 10:24
