Forum Archive Home -> Media -> Help Chosing best DVD code.
| Help Chosing best DVD code. |
| wolfvt13 posted 2008 Jul 15 22:19 |
| What is the best quality of these DVDs?
Brand Code MaxMax GSC003 Egital OPTODISCR008 Huskee GSC003 Princo princo8x02 Samsung OPTODISCR008 Skmax mcc 02rg20 Smartbuy ProdiscF01 BenQ DAXON016S |
| redwudz posted 2008 Jul 15 23:44 |
| JMO, but none of the above. :( If you have no choice, Optodisc has been decent in the past, but I haven't used them in a while. Good quality DVD discs seem to be presently; Taiyo Yuden, Verbatim and some forms of Sony DVD discs. With the others, you may have problems. :( You can go to http://nomorecoasters.com/ and check out some of your brands.
But other may have different opinions. And welcome to our forums. :) |
| [_chef_] posted 2008 Jul 17 15:35 |
| Only the BenQ discs are useful, all others are a waste, because they are FAKES. |
| lordsmurf posted 2008 Jul 17 16:48 |
| BenQ DAXON016S is best there, but if it's made in Malaysia (as opposed to Taiwan), then it's going to be crap too. |
| wolfvt13 posted 2008 Jul 18 22:22 |
| Thank.
I will buy BenQ |
Login/Register to our forum to be able to post here.
