Forum Archive Home -> Advanced Video Conversion -> Help. Avisynth Error Message "no function named deblock"
| Help. Avisynth Error Message "no function named deblock" | ||||
| hypnoticpimp posted 2008 Sep 27 22:23 | ||||
| Script error: there is no function named "deblock" (C:\test\watermarkmov.avs, line 4)
Im trying to convert this avs script with TMPGENC and i get that error message. Can u tell me why? heres my avs file
| 45tripp posted 2008 Sep 27 22:32 | ||||
| patience....
... ... make sure deblock.dll is in the plugins directory of avisynth tripp | ||||
| hypnoticpimp posted 2008 Sep 27 22:39 | ||||
| it is. and still says that | ||||
| hypnoticpimp posted 2008 Sep 27 22:40 | ||||
| do i have to register that dll file first? i have windows vista | ||||
| 45tripp posted 2008 Sep 27 23:03 | ||||
| fortunately,
i know nothing of vista. should not matter. deblock is a standard standalone plugin. no dependencies. you could try manually loading it. extract it someplace else. like to c:\ add:
to the beginning of your script. you should also be using avisource() instead of directshowsource() with an avi. tripp | ||||
| hypnoticpimp posted 2008 Sep 27 23:08 | ||||
heres new avs file
and heres new error message Deblock: need YV12 or YUY2 input (line 5) | ||||
| 45tripp posted 2008 Sep 27 23:16 | ||||
| he he.
what exactly is your avi? why is it rgb? anyway... just call:
after avisource(), anytime before the deblock() call really. tripp | ||||
| hypnoticpimp posted 2008 Sep 27 23:21 | ||||
| Now it says
Script error: there is no function named "tdecimate" line 7 after i did what you told me | ||||
| 45tripp posted 2008 Sep 27 23:26 | ||||
| you need TIVTC
download from here: http://web.missouri.edu/~kes25c/ | ||||
| hypnoticpimp posted 2008 Sep 27 23:30 | ||||
| anyway you can make a zip of all the plugins you have for avisynth. so i can just extract them to plugins folder
Now i got this error Script error: there is no function named fft3dgpu | ||||
| 45tripp posted 2008 Sep 27 23:35 | ||||
my folder is full and messy. not really recommended. but i don;t care for manual loading. anyway, for this script, just one left.
http://forum.doom9.org/showthread.php?t=89941 | ||||
| hypnoticpimp posted 2008 Sep 27 23:36 | ||||
| ahh i had that filter. i just had to do that loadplugin text in the avs file
Thanks. ima test everything now if its a wmv or .asf video i wouldnt use avisource( right? what would i use | ||||
| 45tripp posted 2008 Sep 27 23:40 | ||||
| directshowsource()
you might want to look into why autoloading is not working too.... maybe a restart after the avisynth update. or uninstall, re-install. anyway.. all set yes? good | ||||
| hypnoticpimp posted 2008 Sep 27 23:45 | ||||
| reason i converted twice. cause i needed to edit video first. Now to check on myspace. hope it works |
Login/Register to our forum to be able to post here.
