Forum Archive Home -> Media Center PC / MediaCenters -> HDMI switches
HDMI switches |
| stiltman posted 2009 Sep 30 13:01 |
| I'm looking to get a 4 port HDMI switch.
It will connect to a generation 2 Plasma via HDMI to DVI Other than looking at Newegg reviews, does anyone have suggestions on brands to get or avoid? BTW, so far the only device that will not work HDMI to DVI is a Toshiba HD-A30 I picked up for $20. Plays fine via component, just wont negotiate a HDMI connection |
| redwudz posted 2009 Sep 30 13:15 |
| I've used three different ones from MonoPrice and no problems with any. They use HDMI from my video cards that have a DVI-HDMI adapter and feed my projector. Work fine for BD discs or MKV. http://www.monoprice.com/products/subdepartment.asp?c_id=109&cp_id=10110 |
| SandyB posted 2009 Sep 30 13:21 |
| http://www.cecompass.com/2porthdmiswitchswitcherselectorhdmiver13 ... ching.aspx |
| stiltman posted 2009 Oct 01 21:51 |
| Well, I did some reading at monoprice...BTW thanks for that as I've never been there before.
Looks like the 5 port is better than the 4 port. Since reading all the reviews and doing some research, I may end up getting 5 port and the Fury2 I'm looking at the handshack problem I had with the Toshiba HD player I know I have no problems with HD via component |
| redwudz posted 2009 Oct 01 21:55 |
| MonoPrice is a decent company. Never had problems with them. The HDMI switches I got from them work fine with my setup. My last purchase was for a HDMI splitter so I could use my HDMI output for my projector and my HDMI enabled monitor. Works great. And their cables are a bargain. :)
HDMI handshake is a PITA. Most of my components work fine. But if your video card is off on some weird setting, HDMI may not want to work. It also adds some seconds to any HDMI playback as it negotiates. PowerDVD took forever to display. Total Media Theater is faster for startup, but not a whole lot. |
| stiltman posted 2009 Oct 01 22:13 |
| Too bad my 4 year old 42" plasma still has a great picture. I just can't convience myself to replace a good working TV with a newer just because it's a 2nd generation and has problems with HDCP.
The Fury2 would solve that problem Again, thanks for informing me about monoprice. Great site. Then reading that site I found BlueJeans, another great site |
Login/Register to our forum to be able to post here.
