Forum Archive Home -> Blu-ray Ripping -> HDConvertToX & Haali Media Splitter Problem
HDConvertToX & Haali Media Splitter Problem |
| GreenGrass posted 2009 Aug 22 19:09 |
| Hi,
I need some help on a problem that I'm running into. I have downloaded HDConvertToX and installed the required software for it. "ffdshow" "haali media splitter" "AviSynth" and "XviD". Here is the problem that I'm running into, everytime I launch HDConvertToX, I get the following message "Missing Haali Media Splitter installation Please install Haali Media Splitter". The thing is I do have Haali Media Splitter installed. I have uninstalled and reinstalled, and nothing. Is there something I didn't do during installation? Please some help. Thanks, |
| fatbloke88 posted 2009 Aug 23 05:41 |
| I vaguely remember having to install haali media splitter into the HDconvertex program files folder so that it would see it,maybe wrong as I uninstalled it some time ago,but worth a try to see if it works. |
| buzzqw posted 2009 Aug 23 05:58 |
| what os are you using ?
if windows 7 it's a know bug. HDC isn't able to detect haali in win7 (to fix in next update) anyway you can safely ignore it, if conversion is ok BHH |
| GreenGrass posted 2009 Aug 23 09:47 |
| I'm using Windows XP Professional SP3. |
| GreenGrass posted 2009 Aug 23 10:00 |
| It works now. I had to install it into the applications folder, for HDC to see haali. I originally tried what fatbloke88 suggested, before the comment, but it wasn't in applications folder.
Thanks! |
Login/Register to our forum to be able to post here.
