Forum archive - HD to DV/DivX,etc
http://www.supermediastore.com/
Forum Archive Home -> Camcorders (DV/HDV/AVCHD) -> HD to DV/DivX,etc
HD to DV/DivX,etc
tp3813 posted 2007 Sep 07 06:39
bought a High Definition Canon HV10 camcorder recently, however for some stupid reason they do not include HD software so cant capture to computer.
I knew HD is still fairly new so might have software problems. But got it so I can have top quality archive matreial which can be used later, when HD is more widespread. In the meantine wanted to use the HD material and convert to normal files like DivX, wmv, etc. But not sure if this is possible as I have no software for HD?
Is it possible to convert HD material down to DV or DivX, wmv,etc -and how what software,etc??
Baldrick posted 2007 Sep 07 07:45
Are you looking for free software? Try HDVSplit and see http://forum.videohelp.com/topic303573.html how to convert.
Or else should most new advanced editors be able to capture from the hdv like ulead videostudio, adobe premiere, etc. And yes you can convert down to dv,divx,wmv usings those.
lixid posted 2007 Sep 08 11:06
What about capturing and field order on the HV10 i still have not found a good explanation of what field order to use with the HV10. Any help would seriously be appreciated alot !!! :]
zoobie posted 2007 Sep 08 11:52
Hard to believe Canon didn't supply some sort of cap software. Maybe it's mistakenly missing. You can always ask them.
Anyway, you'll need a pretty fast box to cap HD. 3gHz I believe is the minimum recommended CPU speed, possibly more, with lots of ram.
Mine's only 2.2gHz so I'm downconverting the HD in the cam and outputting DV in the meantime 'till I build another box this Winter. Your cam will do the same but it's just DV.
I received a free copy of VS9 but haven't looked to see if this version will cap HD. Right now, I think Baldrick is right as HDVSplit is the only free thing around.
Since I'm not capping HD, I haven't bothered to figure out the field order. I read that HD is all upper field first but this is unconfirmed.
Soopafresh posted 2007 Sep 08 12:57
AutoMKV
racer-x posted 2007 Sep 08 19:40
All HDV footage I've seen uses TFF (Top Field First) Field Order.
You can capture HDV just fine with HDVSplit or CapDVHS both are fee. And yes a fast PC will help a great deal, I have no problems editing HDV footage in real-time with my AMD 3800x2 Dual-core w/2 GB RAM..........
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
