Forum archive - Hauppaugr WinTV-HVR-1800 IR Remote trouble
http://www.supermediastore.com/
Forum Archive Home -> Media Center PC / MediaCenters -> Hauppaugr WinTV-HVR-1800 IR Remote trouble
agoramilio posted 2009 Oct 31 18:15
Hi,
I apologize first off if this may be in the wrong place, but i couldnt see anywhere else to ask this. I have a HVR 1800 card and I do not for the life of me know where to connect the ir sensor. The manual says to connect it to the "Remote Control Socket" but i dont know if thats supposed to be on the card or on my computer?? Is it even necessary for proper use??
Thx
Baldrick posted 2009 Oct 31 19:10
On the card.
Well, it's necessary if you want to use the remote control...:)
agoramilio posted 2009 Oct 31 19:12
i looked on the card and i didnt see anywhere to hook it up...theres no port for it
http://www.hauppauge.com/pics/hvr1800mckit_board-s.jpg
theres a pic of my card
rallynavvie posted 2009 Oct 31 19:23
The 1800 that has the IR blaster kit has the needed port. One of the 1800s didn't come with a remote and doesn't work with IR blasters. Are you using Media Center?
agoramilio posted 2009 Oct 31 19:23
trying to yes
rallynavvie posted 2009 Oct 31 21:18
Another option is to get the Media Center remote with its IR puck. The puck connects via USB and it supports two IR blasters, or at least the two that I have do.
agoramilio posted 2009 Oct 31 21:28
meh...nvm...i just realized how shit my luck is.....now even though the card is properly installed, drivers up to date and it is recognized in windows, media center doesnt see its there......so ill just say fuck it and wait till i can afford to have some tech guy build me a new pc and configure this thing for $150......thx for the help anyways
ocgw posted 2009 Nov 02 10:40
agoramilio :
You gotta' run the media center setup wizard for TV
ocgw
peace
agoramilio posted 2009 Nov 21 00:41
hey...so ive had some success with getting channels...but i have another question that i may already know the answer to but im scanning for HD channels using WinTV and most are encrypted..is there any way to get those unencrypted?
and if this card doesnt have a port for the ir blaster...why is there one with the card/
rallynavvie posted 2009 Nov 21 08:36
The ATSC tuner on that card only supports open QAM-encrypted channels so if they're using a key (thus not open encryption) then you're not meant to view those channels without the use of the cable box or such. From what I've seen the open QAM channels are DiscoveryHD, ESPN, and the rest of those that normally come with standard HD cable packages.
Login/Register to our forum to be able to post here.
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
