Forum archive - h264 codec in Encore CS4
http://www.supermediastore.com/
Forum Archive Home -> Authoring (Blu-ray) -> h264 codec in Encore CS4
koberulz posted 2009 Oct 14 08:55
When attempting to import an .h264 file into Adobe Encore CS4, I get this error:
What do I need to make this work?
poisondeathray posted 2009 Oct 14 08:59
What are the specifics of the imported file? use mediainfo. And what is the source of the file (where is it from)?
koberulz posted 2009 Oct 14 09:05
General
Format : AVC
File size : 3.98 GiB
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Bit rate : 3 918 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.142
Writing library : x264 core 75 r1251 e553a4c
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3918 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
It's not as easy as x filetype = x codec?
poisondeathray posted 2009 Oct 14 09:26
Is this a raw avc stream, or was it in a container at some point (e.g. m2ts, mkv, mp4)?
Your stream doesn't have any buffer values, so it won't be compliant for blu-ray
Encore should still recognize it if it's raw avc, but it won't pass through untouched (i.e. it will be re-encoded and you will lose quality)
Do you have all updates for PP/encore?
koberulz posted 2009 Oct 14 10:01
It was originally in an mkv file.
What's the quality going to be like relative to DVD?
And as far as I'm aware, Encore is updated.
poisondeathray posted 2009 Oct 14 10:05
If you don't need menus, try multiavchd (allows for simple menus). Otherwise you will have to re-encode to rawavc using compliant settings
It depends on your player if it will or will/not play, some players are finicky
Encore isn't that finicky compared to other programs that require compliance like scenarist
Quality will be better than DVD, if not only for the resolution difference (HD vs. SD)
koberulz posted 2009 Oct 14 10:11
poisondeathray :
What's the re-encoding process?
poisondeathray posted 2009 Oct 14 12:03
Did you extract the stream from the mkv using mkvextract?
The re-encoding process is taking your original source and using blu-ray compliant settings (incl. vbv buffer) to encode to a raw stream. You might use uncropmkv or Megui for this. I would use the original source, not the mkv or you will get another generation loss. It has to be unwrapped (no container), or encore will re-encode it again for even more quality loss
koberulz posted 2009 Oct 14 12:39
Yeah, I used mkvextract to get that file from the mkv.
The mkv is the original source, in this case. Or the closest I've got, at any rate.
What do you mean by unwrapped?
poisondeathray posted 2009 Oct 14 12:56
unwrapped means no container (e.g. no mkv, no mp4, no m2ts), just the raw video (.264 or .h264) and/or audio stream
if you just want to import into encore, and let it re-encode with it's encoder, then re-wrap your video into .m2ts with tsmuxer and it should import
your video has no buffer or hrd information, so it will have to be re-encoded at some point anyways, and some quality loss is unavoidable (whoever made your video didn't encode it with compliant settings for blu-ray)
koberulz posted 2009 Oct 14 14:39
OK, I've got a m2ts file out of it. Don't have any menus set up yet or anything, and it's 4AM, so that'll do me for today.
Completely unrelated issue, though: nothing's showing up in the monitor for Encore. It's a giant pain when attempting to insert chapters, since I've got to view the file in some other program and manually enter timecodes. Any idea how I could fix that?
poisondeathray posted 2009 Oct 14 14:48
The asset has to be placed on a timeline for it to show in the monitor
Also note your video specs 1280x720 @ 29.97 is technically not a valid blu-ray format. 720p24, 720p50/60 are valid. So I don't know how encore is going to treat that, or maybe that's why you can get it to show in the monitor window?
koberulz posted 2009 Oct 15 04:06
It's not just a problem with this project, though It's a problem with everything. Most of the time I have everything in MPEG2 before even importing it, and that wouldn't show up either. It's been a problem ever since I installed the program months ago. I had a similar problem with Photoshop, which was solved with a video driver update, but it's done nothing for Encore. I've reinstalled, I've even formatted my computer and reinstalled everything, due to an unrelated issue. It still doesn't work.
poisondeathray posted 2009 Oct 15 08:08
I'm not sure then, everything works ok here with encore cs4...
Maybe try contanct Adobe support? I can't think of anything else
koberulz posted 2009 Oct 17 12:31
I've imported everything into Encore, but the timeline is set to 4:3, not 16:9, and the button to change it is greyed out. What's the deal?
Also, is there a way I can get a background onto a pop-up menu? Encore's just removing the background and only showing the buttons at this stage.
poisondeathray posted 2009 Oct 17 12:54
I think timeline AR is set to your asset settings or project settings. You can play with the settings or conform the file (right click in the clip bin) by using interpret footage that will switch the timeline AR
Pop up backgrounds in encore cs4 are limited. Difficult to hack
http://kb2.adobe.com/cps/153/tn_15377.html
koberulz posted 2009 Oct 19 10:56
So I've transcoded the timeline, and attempted to build a disc image. It's 17-18 GB all up. However, at some point in the build process, it returns an error about there not being enough space on the media, and the project size is suddenly 28 GB, which is larger than a Blu-Ray disc. What's going on?
poisondeathray posted 2009 Oct 19 11:03
Not sure, sound like encore overshot the bitrate. I don't use encore to encode, just to author
Contact adobe for support
koberulz posted 2009 Oct 20 05:19
I changed the transcode settings, and it worked. The number remained the same the entire way through the project, so I have no idea where the extra 11 GB came from last time.
I mounted the image in PowerISO, and attempted to open it in PowerDVD, which claims that it's an unsupported disc type. Is this a problem with my image, or does PowerISO not work with Blu-Ray, or what? PowerDVD claims to be compatible, so I doubt the problem's there.
poisondeathray posted 2009 Oct 20 09:47
What did you mount with?
I think the pro version of Daemon tools works (but I'm sure the normal version doesn't)
Virtual clone drive works as well
Newer versions of PowerDVD apparently have issue with home-brew blu-ray ISOs. Really old (6.x) versions work better
You could use other software like WinDVD as well to check the image (which is what I use)
Or maybe you did something wrong with authoring
koberulz posted 2009 Oct 21 08:40
Mounted it with Virtual CloneDrive, and PowerDVD plays it now.
What software do you recommend to burn the ISO to disc?
poisondeathray posted 2009 Oct 21 08:56
imgburn udf 2.5 profile . Nero works fine too
I've never used encore to burn, so I don't know if that works
koberulz posted 2009 Oct 21 10:54
I've used encore in the past, but it's far too iffy for my liking. I build an ISO to test anyway, I figure I might as well burn that.
I'll give ImgBurn a shot just as soon as I get a Blu-Ray writer, which should hopefully be before the week is out.
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
