Forum Archive Home -> Media -> Growing very tired of Epson's R200 - R220
| Growing very tired of Epson's R200 - R220 | ||||||||
| stiltman posted 2008 May 29 20:56 | ||||||||
| I have both R200 and R220 and I'm about to throw them out the window.
Constant cleaning and waisting ink in order for it to print right. I've used both generics and OEM ink. Right now I had to do 5 cleanings in order for the black to come alive and this is with OEM carts :evil: :evil: :evil: So what are my options, keep in mind I live in the US???? I want something new, but I don't care if I have to mod it or not. I saw the HP for $140 at BB today, but that seems pretty steep. Plus, HP drivers have got to be the most bloated around... Also getting generic ink is a must or dang close to it :) What would you recommend? Printing to TY's hub printable and Ver's DLs | ||||||||
| aedipuss posted 2008 May 29 21:36 | ||||||||
| not much good on the printer front these days. canon went to chipped carts recently like everyone else. the epson r280 with a continuous ink system may be my next color/photo/cd printer, and a personal laser for general print jobs. | ||||||||
| Bodyslide posted 2008 May 29 22:31 | ||||||||
| I got a great deal on the Epson 595 all in one...That also does CD prints. Bought a CIS (haven't installed it yet) and it works very good..... | ||||||||
| offline posted 2008 May 29 23:39 | ||||||||
Extreme prejudice. I'd apply a baseball bat first, then throw. I nursed an R210 and it was such a vampire for ink it was hardly funny. That plus tray eccentricities, ink counter issues as well as refill/reset problems, drove me to Canon. Unlike Epson, their chipped carts don't require resetting as the ink level function can be easily and permanently over-ridden via the paper feed button. Rather than risk drilling holes in the existing tanks, I swapped the chips over to CIS unit (but for low volume printing a set of refillable tanks are just as good). Pros: Ink costs are now reasonable, much faster output, much less wasted ink Cons: Supplied Canon software won't print right to the hub (I have not tried a PS template though) I heard somewhere that DVD converter kits can be purchased for US models. For DVD printing you don't need an expensive $$$ 8 colour system | ||||||||
| paulw posted 2008 May 30 02:36 | ||||||||
I'm using Canon CD-LabelPrint V1.3.0 and it prints rite to the center hub. Click on the "Select Paper" icon and create a user defined setting with the print area inner to say 20mm. Click OK and your done. | ||||||||
| Bjs posted 2008 May 30 04:35 | ||||||||
| Don't just blame the carts.
Remember, these printers have a separate print head, and this is where the problem develops ... for what its worth to replace, your better just getting another printer. Mine costs $115.00+ for replacement print head, and I'm only 120km from nearest spare parts service center. If the unit appears to be suffering from clogging, I suggest getting a small bottle of mentholated spirits, and an eye dropper, remove carts, and place one drop onto the area where the carts sit on the print head and give it time for it to be absorbed, then run a few print cleans. Ive rescued a few clogged printers using this method. | ||||||||
| jman98 posted 2008 May 30 05:35 | ||||||||
| I wanted a new printer, so I bought some Epson model. It may have been the 220. To be honest, I'm not sure. The stupid thing refused to recognize the ink cartridges that got shipped with it. I searched on the internet and found out that this does happen and there is no fix for it. You have to replace the printer. I decided I had enough of Epson's b.s. If they couldn't make a printer that could recognize its own ink cartridges, they didn't need my money.
I got a refund and instead got the Canon Pixma ip4500. Because of a lovely US patent that Epson holds, Canon can't sell printers in the USA that can print to CDs/DVDs. However, you can find info on the internet on how to hack these printers to European settings. The European models can print to CDs/DVDs. Buy a disc tray on Ebay and you are good to go. Info is here: http://pixma.ulmb.com/?p=105/The-Five-Easy-Steps.html I love the printer. I've had no b.s. with the ink cartridges that came with it. In the past I had HP printers and while they are OK, their ink cartridges are the smallest in the business - they are always running out and having to be replaced. You can print maybe 20-30 pages on the HP printers I've had before you have to replace the ink cartridges. That sucks. | ||||||||
| offline posted 2008 May 30 06:03 | ||||||||
I had version 1.2.1. I'll try an update, cheers. -edit- nope, no good. :( My R210 could print right on a printable hub (even past it), but my canon (ip5300) seemingly can't get right to the edge on fully hub printable DVD's. ![]() | ||||||||
| FulciLives posted 2008 May 30 07:57 | ||||||||
| A friend of mine has the Casio CW-75 which is a small stand alone THERMAL printer for printing TEXT and VERY SIMPLE GRAPHICS onto a CD-R or DVD-R.
It looks like this:
It can be used all by itself (which is how my friend uses it) or you can connect it to a MS Windows running computer via USB and use software to print onto it. I like it because it looks professional (plain bold black text on a silver disc) and will not smudge or come off. You also don't need any "fancy" discs. The regular all silver (silver lacquer) Taiyo Yuden discs from RIMA.COM work great and are cheap. The 100 pack of CD-R discs are only $23.99 + shipping and the 100 pack of DVD-R discs are only $25.99 + shipping. His only complaint ... one ribbon will just barely do 100 discs and that ribbon costs something like $10.00 + shipping ($25.00 + shipping for a 3 pack). I have to imagine that is still a hell of a lot cheaper than full color ink jet printing ... not to mention it is a hell of a lot less hassle free. I always wanted to get one myself but could never justify spending the money on it ... I'm cheap ... and a sharpie marker and careful hand-writing works for me LOL - John "FulciLives" Coleman P.S. The Casio CW-75 used to go for around $125 but I see it is now only $100 on the Casio website. Maybe I will pick up one of these after all. | ||||||||
| bigjimmpls posted 2008 May 30 07:59 | ||||||||
| I also was tired of Epson's Crap. So I went and bought an HP Photosmart D5160. I have never looked back. Uses very little ink and it isn't constantly cleaning the heads. Also with HP's software I can print right to the center hub with no issues. I think I paid $59 for it about 3-4 months ago. I have to say I have never had a problem with it.
GOOD LUCK!!!!! | ||||||||
| genki500 posted 2008 May 30 11:00 | ||||||||
| I had similar trouble, after talking to a very nice Epson tech - here is a tip to prevent clogging: Leave printer on all time, print a 3 x 5 photo once a week. Since then (more than two years), not a clog. By the way, leave printer on all the time, actually save on ink. | ||||||||
| Seeker47 posted 2008 May 30 13:05 | ||||||||
How do you go about transplanting those chips so that they continue working, and the printer functions normally ? If this is a reasonable DIY project, I'm sure a number of readers here would welcome some detailed instructions.
The only printers I can recall that had the print head in each cartridge (sounds like a really good idea, the reality may have been otherwise ?) were some Lexmark models, but that was a while ago and I don't know if they kept on doing that. Their printers were fine for text, but were not that well regarded for photo work. | ||||||||
| aedipuss posted 2008 May 30 15:00 | ||||||||
| here's a basic overview for a canon 4500 chip swap. printer will store the info about the refilled cart in memory and that voids any remaining warranty.
http://www.meritline.com/canon-cli8-pgi5-instruction.html | ||||||||
| stiltman posted 2008 May 30 16:34 | ||||||||
| The Photosmart D5160 is pretty much out of stock everywhere
Next one would be Photosmart D5360 for $46 + tax at CC I was think about using an IV to suck out the ink from the tube in the Epson then inject a little ethenol to clean it out, but that would be a total deal breaker if it messed it up...I want to have a Plan B if I go that route :) Also which current cannons can be modded? Who about generic ink for that model Or you can alway point me to a website so I can do the research :) | ||||||||
| Nelson37 posted 2008 May 30 17:46 | ||||||||
| I have used the Cartridge Flush solution from the Epson refill kits to clean clogs on several occassions. Let it sit for a few hours, do some test prints, repeat if necessary. Just a drop or two.
I keep my R200 on a battery backup unit, this prolongs ink life significantly. Been refilling stock cartridges for a couple years now, am on my 2nd R200. Several thousand pages each, plus some pictures and DVD's, I'd buy another one. If I could have re-set the End of Life chip on the first one, it would still be working. Bad Epson. CIS systems too expensive for me, at 2x that of the printer. Some sort of do-able ink refill system is now my primary consideration in evaluating inkjet printers. | ||||||||
| bourboner posted 2008 May 30 18:11 | ||||||||
| I read a tip here once to make sure you print a test page every day on your Epson, and you won't get clogged heads. I've been doing that these last 12 months and do not get clogged heads anymore. Just don't let your printer sit idle for a few days!
I recently bought this too - http://www.rihac.com.au/ - which uses its own chipped cartridges. Their ink is much better than the $3 generic inks that are available. Blacks are BLACK! I think Epson printers are very good, the quality of prints is excellent. I haven't had a Canon but I've seen prints made which I considered sub-par (though probably the person hadn't tweaked the quality settings I suppose). With the Epsons, you just have to maintain it a bit, not just let it sit idle on your desk and expect it to print flawlessly when you turn it on after a few weeks inactivity. | ||||||||
| stiltman posted 2008 May 30 18:50 | ||||||||
I think I'll try some ethenol tonight. Pull all the carts, suck as much ink out of the tiny tubes as I can. Fill it up with ethenal, and let it sit for awhile Replace the carts and run some test prints through. If it breaks the thing, I'll get the HP at CC.... However I do still have my R200...Replaced it because of the tray problem and got the R220 on sale for the cost of the ink. So I could always go back to it too, but with the newer R220 tray | ||||||||
| paulw posted 2008 May 30 21:01 | ||||||||
That's strange. You did create a new user defined label and not try to modify the default. Mine looks like this. ![]() | ||||||||
| lordsmurf posted 2008 May 30 22:55 | ||||||||
| People spent maybe 10 seconds at most looking at a disc labels. Complete waste of time. Good DVD cases (laser printed) and good DVD menus (Photoshop and/or Premiere work) are where effort should be spent.
Just my take. Disc ink is a waste of time and money. The only time I -must- have disc artwork is when sending a job for press. | ||||||||
| stiltman posted 2008 May 31 02:12 | ||||||||
| Well, I gave it a good cleaning with methanol tonight
Sucked out the ink out of the little tubes before forcing in the methanol in to each one. I did a stupid thing though. The ink I sucked out, I tried forcing back into each tank....I'm pretty sure this messed up my light cyan. All the other colors are now printing fine, except for the light cyan. I can remove the tank and then re-install it. The do a print of all light cyan and it will slowly fade out to nothing. Guess I'll buy some more ink tomorrow. All this has pretty much run each tank empty :( Or I may just buy the HP to see how it works. I can always clean the R220 or R200 with ethanol again, and start with fresh ink if the HP sucks Thanks for the Flushing idea, and ethanol works great | ||||||||
| offline posted 2008 May 31 03:32 | ||||||||
aedipuss provided a good link.
You can use super glue, double sided tape or even melted plastic to secure the chips. So long as you match each chip for the right cart colour you are fine. Remove them with a stanley knife (box cutter) or scalpel. Epson printers additionally require a chip reset via a battery powered device, but some work with a certain Russian utility. Canon do not require anything except pressing the paper feed/resume button
Ah.... got it now thanks. A case of user error on my part.
I think they swap the OEM Epson pigment black for a dye based formula. Their shop is near where I live but they ship all over the world. I can't say if their CIS products are better than others as I have only ever installed their CIS systems. I can say their after sales technical support is pretty damn good. | ||||||||
| bourboner posted 2008 May 31 04:05 | ||||||||
The newer Epson models use the "Claria" dye-based inks, not pigment. Yes, the Rihac CIS systems use dye-based. Here is their info on "dye vs pigment" FWIW - http://www.rihac.com.au/info_pages.php?pages_id=2 | ||||||||
| ghost13 posted 2008 Jun 19 03:55 | ||||||||
| Hiya, mate. I also have an Epson R220 and I personally love it... Well, I had to modify it a bit first, because the print cartridges cost just as much as the printer did when I bought it. I got a CIS system from a place online and now I'm not paying anywhere near as much as I would've if I had to buy cartridges. This is my first post, so I don't want people thinking I'm a troll so I won't give the link here. But if you're interest, drop me a PM and I'll give you the link. Also, if you're all interested, I can post a picture of what it looks like.
ghost | ||||||||
| stiltman posted 2008 Jun 19 12:57 | ||||||||
I have both the R200 and R220 now sitting on a shelf :) I'm now using a HP Photosmart D5360. Ink cost less and it seems to be working fine. As soon as the included ink carts run out, I'll be installing the color (HP75) and then not installing the black only, but the multi color plus black cart(HP99). That way it will match the same color options as the Epson 6 cart design | ||||||||
| ghost13 posted 2008 Jun 19 13:17 | ||||||||
No worries, mate. Use what works for you. :) All the best. ghost | ||||||||
| Thadius856 posted 2008 Jun 25 23:58 | ||||||||
| Been using an Epson R340 since right after they came out. Got mine for a great deal: retailed for $200, on sale for $180, incorrectly had $100 price tag on it from an R200.
Bought a CIS on eBay that same week for $25, prefilled. Still buying ink for it through Atlantic Inkjet for around $35 a liter. Great price, and works pretty well. However, I still use factory cartridges for my printable media. Superior inks should be used whenever possible - no use paying for expensive media if you're just going to spray cheap ink on it. It's been through a lot and still going strong. Just finished my 20th ream on the CIS, and have already printed at least 500 discs. For what it's worth, I'm very happy with my purchase! |
Login/Register to our forum to be able to post here.
