VideoHelp.com forum archive
http://www.supermediastore.com/
Forum Archive Home -> ffmpegX general discussion -> Going from avi to flv, generated file is empty
jearbear posted 2008 Jun 13 15:34
Hey, all, I'm trying to convert an avi to an flv using ffmpegX 0.0.9y. However, the generated file always comes out empty. It's a video only file, that is mpeg4, yuv420p, 640x480. Is there a codec problem or something?
Thanks!
Case posted 2008 Jun 15 15:35
The current version isn't advanced enough to figure out your specific situation on its own; you'll need to guide it a little bit:
In the Audio tab, de-select Encode audio (screenshot).
If that doesn't help, please post the Process Information log (accessible by clicking the blue "i" in the ffmpegX Progress window).
jearbear posted 2008 Jun 15 17:05
That was exactly it - I just needed to turn off the audio encoding. Thanks!
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
