Forum Archive Home -> Programming -> get FPS value from mediainfo into a bat script
get FPS value from mediainfo into a bat script | ||
| ricardouk posted 2009 Oct 24 12:40 | ||
| Hi everyone!
Im doing a semi automatic conversion script and ive stopeed at the bit where i need to get the FPS value from a file on to the script. Is there any easy way of doing this, i need the fps because it seems mp4 box needs that value to mux 264+aac into mp4 container, im using mencoder...ive read that mencoder can also "read" the fps from a file, mediainfo can also read that value. Any suggestions? | ||
| ikk posted 2009 Nov 10 09:27 | ||
| use -identify switch, but not with mencoder, with mplayer.
mplayer will print some output to stdout.
Login/Register to our forum to be able to post here.
