Forum archive - General question: best practices to create/generate a preview
http://www.supermediastore.com/
Forum Archive Home -> Linux -> General question: best practices to create/generate a preview
nickman00 posted 2009 Jun 14 02:21
Hello All,
I'm just wondering what are your customs and practices to create a "preview" of a video?
Why I'm asking is because I'm playing around with many encoding settings and options to bring out the best. But the problem is that I can see the final results only after the full conversion. Mostly I'm interested only in the following:
- some kind of general quality (I don't want to browse through the full movie, I usually do only with the first 15 minutes)
- the final filesize of avi
At this moment the problem is that I can see these above only after the x hour conversion.
Do you know how could you get the above two, but without encoding the whole video?
I'm a mplayer/mencoder/*nix user so the ideas for this would be the best - but naturally any theoretical advices are welcomed too.
thanks,
n
jimmalenko posted 2009 Jun 14 03:42
Cut your sources to the first 15 minutes, then encode them ? :scratch:
Chris K posted 2009 Jun 14 03:43
I'm not a mencoder user myself but it seems to be possible to encode a arbitrary part of your source.
http://www.misterhowto.com/index.php?category=Computers&subca ... h_mencoder
Hope this helps!
Login/Register to our forum to be able to post here.
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
