Forum archive - from karaoke dvd to karaoke vcd ?
http://www.supermediastore.com/
Forum Archive Home -> VCDEasy General -> from karaoke dvd to karaoke vcd ?
marckos posted 2005 Oct 06 01:39
hello.
my friend got this karaokes dvds, but my machine is old and only takes vcds, is there a way to convert those dvd to vcds to play in my karaoke machine ?
thanks.
Znooky posted 2005 Oct 06 14:03
Hi!
There should be no problem with converting those DVD:s to VCD. I'm not sure if the text is a subtitle on the kareoke DVD or if it's encoded within the video stream. If it's as a separate subtitle you have to encode the subtitle with the video if you are making a VCD as VCD:s doesn't support subtitles.
However if the text is within the video, then you can simply convert the DVD to a VCD. There's a lot of guides for that here at Videohelp. Check them out.
// Znooky
Cornucopia posted 2005 Oct 06 14:11
Audio may be a little tricky:
DVD audio may be simple 2 stream switchable, or could be VCD-style [L vs. R] channel switchable, or could be true "Karaoke-mode" DVD which is similar to normal 5.1 audio, but each channel is mixed live together (in ways decided by the user) to form the composite sound (e.g.: Vocal Guide + Harmony + Background Music (stereo)).
Depending on which type, there will be different methods to extract/combine/recode.
marckos posted 2005 Oct 07 04:56
the dvd seems to have 2 different audio. lpcm and ac3. now the question is how do I convert this to vcd and keep the chapters ?
Cornucopia posted 2005 Oct 07 10:43
Rip DVD with DVD Decrypter & Demux streams.
You've got:
MPEG2 video, as M2V
LPCM audio, as WAV
AC3 audio, as AC3
Chapter log, as ?TXT?
Convert Video:
Many usual ways here...ex: D2V-->TMPGEnc-->M1V file
Make sure you create I-frames at the frames listed in the Chapter Log.
Convert Audio:
Open WAV in CoolEdit (or similar), mix to mono WAV. Save as "***_L.WAV"
Open AC3 in BeSweet, convert to PCM/WAV. Then do the same as LPCM WAV above, but save as "***_R.WAV"
Open both in CoolEdit (multitrack mode) and mix down to new Stereo WAV.
Convert to MP2 in TMPGEnc (224kbps, Dual Mono, 44100Hz)
Mux using TMPGEnc tools to create MPG
Make VCD in VCDEasy, using Chapter log to create chapters.
Done!
marckos posted 2005 Oct 07 14:55
wow ! seems like a lot of work.
but Im on it.
thanks man ! u rock :D
Login/Register to our forum to be able to post here.
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
